I developed a Qt-based application and I want to run it on a VF61 module running WinCE 6 (V1.4 beta 1 at the moment).
Which is the suggested way to deploy Qt dll files?
I know I can put the dll’s either in the same folder as my application or in the /Windows folder (maybe other options are available, I don’t know).
Are there advantages or disadvantages with the several approaches (in terms of boot time, overall performance, …)?
I see this is a task that requires some time and some preliminary investigation.
I have VS2008 + platform builder and I can download BSP and Workspace.
I think I’m going to try this approach in some weeks
After a lot of time it’s time to integrate Qt dll into CE 6 image, and optimize this image as much as possible excluding what I don’t need.
I have VS2008 + platform builder installed.
I downloaded Toradex BSP + Workspace.
First question: where should I extract and save BSP and Workspace on my hard drive?
So put BSP (COLIBRIVYBRIDBIN) to c:\WINCE600\platfrom and OSDesign to c:\WINCE600\OSDesign
Open VS2005 and select File → Open → Project / solution and select *.pbxml file inside OSDesign. You should not get any warnings or errors. If you do please paste screenshot here.
Then select “Release” as build type so it will build correct image. After that do clean sysgen on the image to build it.
Maybe you have a bit different update level or a bit different compiler version. I think image you get is OK. I also test every release building this on a bit different version and never had issues.
