Dear support, i have one issue on one VF61 board.
It works right for some days, but randomly it stio to respond on ethernet and it is not possible to pint it.
I need to remove lan cable and then reconnect to restart functionality. It is strange.
Here attached the system journal log, i hope this can help youlink text.
Let me know if you need more information.link text
Thanks Roberto
Dear support, today i had another issue simailar to other one,
Here attached the journal.
By the way is there a limit about the space of journal file?
In the journal i saw this message:
Jun 07 07:59:05 AlbenV3_0480 systemd-journald[28488]: System journal (/var/log/journal/) is 16.0M, max 16.0M, 0B free.
Jun 07 07:59:06 AlbenV3_0480 systemd-journald[28488]: Missed 125536 kernel messages
I’ll lock forward about your reaply
Hello @signo_ri,
Thank you for your post in the community!
You can clear the log journal by following the instructions here: Managing Journal Size - The Ultimate Guide To Logging
Could you please tell us more about the issue? How long have you been using this board? And this error appears randomly? Can you please also share the dmesg log?
Janani
Hello Janani,
I am working with Roberto who wrote the original post.
I actually submitted the question on stackoverflow with wider logs and some more details:
https://serverfault.com/questions/1065947/network-connectivity-problems-on-angstrom-linux
The problem seems to appear randomly. We have 6 boards under test at the moment for a new system we are developing and the problem has already occurred on 3 of them in the last week.
We are not doing any network intensive of CPU intensive operation: we are acquiring data with a 200Hz sampling rate, which can be downloaded via TCP.
Mario
dmesg logs don’t seem to provide any more information than journalctl:
[26438.623301] avahi-daemon: page allocation failure: order:0, mode:0x2080020
[26438.640314] CPU: 0 PID: 235 Comm: avahi-daemon Tainted: G L 4.4.59-2.7.2+g7cfa321 #2
[26438.668971] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[26438.685685] Backtrace:
[26438.698209] [<800134ac>] (dump_backtrace) from [<800136a4>] (show_stack+0x18/0x1c)
[26438.726338] r7:00000030 r6:00000000 r5:00000000 r4:02080020
[26438.742764] [<8001368c>] (show_stack) from [<802a1a1c>] (dump_stack+0x24/0x28)
[26438.771377] [<802a19f8>] (dump_stack) from [<80091580>] (warn_alloc_failed+0xe4/0x120)
[26438.801035] [<800914a0>] (warn_alloc_failed) from [<80094590>] (__alloc_pages_nodemask+0x754/0x900)
[26438.831882] r3:00000000 r2:00000000
[26438.846123] r6:00000000 r5:02080020 r4:80879d0c
[26438.861215] [<80093e3c>] (__alloc_pages_nodemask) from [<80094938>] (__alloc_page_frag+0x154/0x17c)
[26438.891053] r10:8e5a6800 r9:00000040 r8:60030113 r7:00000880 r6:02080020 r5:00000900
[26438.920182] r4:80872078
[26438.932934] [<800947e4>] (__alloc_page_frag) from [<804bfbe8>] (__netdev_alloc_skb+0xa8/0x104)
[26438.962787] r7:00000880 r6:80872078 r5:8e5a6800 r4:00000900
[26438.979540] [<804bfb40>] (__netdev_alloc_skb) from [<803bb6c4>] (fec_enet_rx_napi+0x2dc/0xad4)
[26439.010774] r9:00000040 r8:8ec4a020 r7:00000880 r6:8e5a6800 r5:0000003e r4:8d86ba80
[26439.042440] [<803bb3e8>] (fec_enet_rx_napi) from [<804cb9b4>] (net_rx_action+0x1d8/0x2b4)
[26439.075333] r10:0027a266 r9:8de1dea8 r8:0000012c r7:8084ee80 r6:00000040 r5:00000001
[26439.108297] r4:8e5a6d40
[26439.123048] [<804cb7dc>] (net_rx_action) from [<800249dc>] (__do_softirq+0xf4/0x25c)
[26439.155446] r10:40000003 r9:8087a900 r8:00000100 r7:8de1c000 r6:8087a90c r5:00000003
[26439.188264] r4:00000000
[26439.202948] [<800248e8>] (__do_softirq) from [<80024e18>] (irq_exit+0xe0/0x114)
[26439.234483] r10:01d30490 r9:90003100 r8:8e406000 r7:00000001 r6:00000000 r5:00000000
[26439.266758] r4:80857e80
[26439.281074] [<80024d38>] (irq_exit) from [<8004da2c>] (__handle_domain_irq+0x60/0xb0)
[26439.313223] r5:00000000 r4:80857e80
[26439.329012] [<8004d9cc>] (__handle_domain_irq) from [<800093f4>] (gic_handle_irq+0x50/0x84)
[26439.361542] r9:90003100 r8:8de1dfb0 r7:90002100 r6:9000210c r5:808463a0 r4:80857fc0
[26439.393938] [<800093a4>] (gic_handle_irq) from [<80014434>] (__irq_usr+0x54/0x80)
[26439.426250] Exception stack(0x8de1dfb0 to 0x8de1dff8)
[26439.443777] dfa0: 01d3049d 01d304a9 7ee28a28 7ee28a2c
[26439.476526] dfc0: 0000005c cccccccd 0000007f 00000100 0000000a 00000000 01d30490 ffff3f00
[26439.509037] dfe0: 7ee28a60 7ee28a08 51eb851f 76f139c0 20030030 ffffffff
[26439.527954] r9:00000000 r8:10c5387d r7:10c5387d r6:ffffffff r5:20030030 r4:76f139c0
[26439.560010] Mem-Info:
[26439.573953] active_anon:2506 inactive_anon:42 isolated_anon:0
[26439.573953] active_file:24260 inactive_file:25691 isolated_file:0
[26439.573953] unevictable:0 dirty:16 writeback:0 unstable:0
[26439.573953] slab_reclaimable:2069 slab_unreclaimable:1621
[26439.573953] mapped:2610 shmem:92 pagetables:164 bounce:0
[26439.573953] free:3445 free_pcp:21 free_cma:3409
[26439.677021] Normal free:13780kB min:1928kB low:2408kB high:2892kB active_anon:10024kB inactive_anon:168kB active_file:97040kB inactive_file:102764kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:260096kB managed:249040kB mlocked:0kB dirty:64kB writeback:0kB mapped:10440kB shmem:368kB slab_reclaimable:8276kB slab_unreclaimable:6484kB kernel_stack:752kB pagetables:656kB unstable:0kB bounce:0kB free_pcp:84kB local_pcp:84kB free_cma:13636kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[26439.804065] lowmem_reserve[]: 0 0
[26439.819243] Normal: 3*4kB (UEC) 49*8kB (UEC) 62*16kB (EC) 57*32kB (C) 51*64kB (C) 25*128kB (C) 8*256kB (C) 4*512kB (C) 0*1024kB 0*2048kB 0*4096kB = 13780kB
[26439.857901] 50047 total pagecache pages
[26439.873512] 0 pages in swap cache
[26439.888278] Swap cache stats: add 0, delete 0, find 0/0
[26439.904875] Free swap = 0kB
[26439.918777] Total swap = 0kB
[26439.932455] 65024 pages RAM
[26439.945755] 0 pages HighMem/MovableOnly
[26439.960101] 2764 pages reserved
[26439.973462] 4096 pages cma reserved
[26439.991067] systemd-journald[84]: /dev/kmsg buffer overrun, some messages lost.
[26440.018798] mmc0: Timeout waiting for hardware interrupt.
[26440.068779] usb 2-1: USB disconnect, device number 2
[26440.087261] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - nonzero urb status: -71
[26440.116742] mmcblk0: timed out sending r/w cmd command, card status 0x400900
[26440.146989] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[26440.191982] mmcblk0: error -84 transferring data, sector 3178328, nr 512, cmd response 0x900, card status 0xb00
[26440.247807] ftdi_sio 2-1:1.0: device disconnected
[26440.291453] systemd[1]: systemd-journald.service: Main process exited, code=dumped, status=6/ABRT
[26440.364053] mmc0: tried to reset card
[26440.382784] systemd[1]: systemd-journald.service: Unit entered failed state.
[26440.401593] systemd[1]: systemd-journald.service: Failed with result 'core-dump'.
[26440.509595] systemd[1]: systemd-journald.service: Service has no hold-off time, scheduling restart.
[26440.545830] systemd[1]: Stopped Flush Journal to Persistent Storage.
[26440.594088] systemd[1]: Stopping Flush Journal to Persistent Storage...
[26440.642692] systemd[1]: Stopped Journal Service.
[26440.675255] usb 2-1: new full-speed USB device number 3 using ci_hdrc
[26440.720574] systemd[1]: Starting Journal Service...
[26440.996773] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[26441.180844] usb 2-1: Detected FT232RL
[26441.356894] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB1
[26442.303986] systemd[1]: Started Journal Service.
[26490.297347] usb 2-1: USB disconnect, device number 3
[26490.322459] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[26490.374615] ftdi_sio 2-1:1.0: device disconnected
[26550.495187] usb 2-1: new full-speed USB device number 4 using ci_hdrc
[26550.688618] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[26550.710602] usb 2-1: Detected FT232RL
[26550.733660] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB1
[96297.665370] usb 2-1: USB disconnect, device number 4
[96297.683227] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[96297.717695] ftdi_sio 2-1:1.0: device disconnected
[96312.904491] usb 2-1: new full-speed USB device number 5 using ci_hdrc
[96313.096720] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[96313.119057] usb 2-1: Detected FT232RL
[96313.141845] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
Hello @mnicolas , @signo_ri ,
One option here would be to check with the BSP 2.8 to check if the problem still exists. That is our supported LTS BSP. When this problem still occurs, there could be a possibility that the there is a problem with the Hardware.
Please let us know how this works at your end.
Janani
Hello @saijanani.tx,
is there any known issue with the version of Linux we are using?
Changing all our environment is not that easy at this stage of the project. The problem hasn’t occurred for the last few days so I have not been able to investigate any further.
Mario
Hello @mnicolas ,
The BSP that you have is an intermediate release. That’s why for better feature/ to let you know about known bugs or errata, it lI advisable to upgrade to a newer BSP. Our advice is to kindly upgrade to either to Bsp 2.7b4 or 2.8b7.
Janani
