These questions could be better answered by the Mender team, as the meta-mender-toradex-nxp layer is managed by them and they can point out the reasonings clearly.
Could you please reach out to the Mender team in this regards?
Thanks for the reply. I have reached out to the Mender team. There is a U-boot patch file that does not apply to the latest sources (0001-Integration-of-Mender-boot-code-into-toradex-U-Boot.patch). They have asked me to manually adjust that patch file for the latest sources. I will try to do so.
Regarding the OFFSET variables shown in the error logs above, I can also fix them, but I need to figure out their correct values. Do you have any insight into this?
My conclusion is that the Apalis IMX8 is not currently supported for a Yocto build with Mender enabled, and anyone wishing to do so must manually fix (at least) these two issues. Is that correct?
Thank you for the update here from the Mender team. Like I said before, this question would be best answered by the Mender team. And after discussion with them, if you arrived at this conclusion, I would proceed and try it
