probably, recently arm32v7-debian-qt5-wayland:2 updated
and now after
docker save register/application | ssh torizon@192.168.1.7 docker load
I get
Error processing tar file(exit status 1): write /opt/App_dir/bin/App_bin: no space left on device
or
Error processing tar file(exit status 1): Error setting up pivot dir: mkdir /var/lib/docker/overlay2/e2a0040189aba59f1b7aeac21efbe5fdf3f4917509b1246bf4e13b3a1ff779ae/diff/.pivot_root135283437: no space left on device
The size of the image is the same as before arm32v7-debian-qt5-wayland:2 was updated, 606 MB
There is free space on the board:
apalis-imx6:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 1031352 22572 1008780 3% /run
devtmpfs 961364 0 961364 0% /dev
/dev/disk/by-label/otaroot 3631504 2600500 826820 76% /sysroot
tmpfs 1031352 0 1031352 0% /dev/shm
tmpfs 1031352 0 1031352 0% /sys/fs/cgroup
tmpfs 1031352 12 1031340 1% /tmp
tmpfs 1031352 8 1031344 1% /var/volatile
tmpfs 206268 0 206268 0% /run/user/1000
~$ docker images
register/App-client latest 2781e9ae398b 31 minutes ago 606MB
register/App-weston latest 346d3da9bd2f 2 months ago 288MB
qt5-target latest 0cdd441ae956 2 months ago 593MB
portainer/portainer latest 9b438d60114e 2 months ago 62.4MB
apalis-imx6:~$ docker system prune
WARNING! This will remove:
- all stopped containers
- all networks not used by at least one container
- all dangling images
- all dangling build cache
Are you sure you want to continue? [y/N] y
Total reclaimed space: 0B
To build the image I take the example for build with Qt and modify that
ARG BASE_NAME=arm32v7-debian-qt5-wayland:2
FROM torizon/$BASE_NAME
SHELL ["/bin/bash", "-c"]
RUN apt-get -y update && apt-get install -y --no-install-recommends \
qml-module-qtquick-controls2 \
qml-module-qt-websockets \
qml-module-qt3d \
qml-module-qtaudioengine \
qml-module-qtav \
qml-module-qtbluetooth \
qml-module-qtcharts \
qml-module-qtdatavisualization \
qml-module-qtgraphicaleffects \
qml-module-qtgstreamer \
qml-module-qtlocation \
qml-module-qtmultimedia \
qml-module-qtnfc \
qml-module-qtpositioning \
qml-module-qtqml-statemachine \
qml-module-qtquick-dialogs \
qml-module-qtquick-controls \
qml-module-qtquick-extras \
qml-module-qtquick-scene2d \
qml-module-qtquick-scene3d \
qml-module-qtquick-shapes \
qml-module-qtquick-templates2 \
qml-module-qtquick-virtualkeyboard \
qml-module-qtsensors \
qml-module-qtwayland-compositor \
qml-module-qtwebchannel \
qml-module-qtwebengine \
qml-module-qtwebkit \
qml-module-qtwebsockets \
qml-module-qtwebview \
qt5-qmltooling-plugins \
openssh-server \
gdbserver \
rsync \
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
# Allow empty password hack (only for developement)
# sed -i /etc/ssh/sshd_config -e 's/UsePAM yes/UsePAM no/g'
RUN sed -i 's/nullok_secure/nullok/g' /etc/pam.d/common-auth && \
echo "PermitEmptyPasswords yes" >> /etc/ssh/sshd_config && \
echo "PermitRootLogin yes" >> /etc/ssh/sshd_config && \
sed -i /etc/shadow -e 's/root:.*/root::18254:0:99999:7:::/g'
RUN test $(arch) == "aarch64" && { cd /usr/lib/aarch64-linux-gnu/ && ln -s libGL.so.1.7.0 libGL.so.1.2; } || true
COPY entrypoint.sh /entrypoint.sh
COPY App_bin /opt/App_directory/bin/
COPY App_translation.qm /opt/App_bin/bin/
RUN echo "set -o allexport; . /etc/environment; set +o allexport;" >> /etc/profile
ENTRYPOINT ["/entrypoint.sh"]
App_bin is 12 MB
qml translation file is 22 kB
entrypoint is 403 B
Last week it worked.
Today repo updated and save fails.
How to find the bug?
