We have a custom carrier board with Verdin SOM. To its native HDMI port we connect a MI0700BNT-7CP1-HB1 screen. The screen works, but with wrong resolution. Both our linux and the depo application preinstalled on Verdin has this error.
I checked EDID, and the desired resolution is specified as the only Detailed Timing Descriptor. Here is the EDID:
# xxd -p -g1 /sys/class/drm/card0-HDMI-A-2/
00ffffffffffff004a8b7e56d905000004120103eb3120780aaec5a2574a
9c251250543fdf8001010101010101010101010101010101941100b04058
192030203600da28110000180000000f0068646d690a0a0a0a0a0a0a0a0a
000000fd00384b1c530f000a202020202020000000fc0057323235320a20
202020202020001a
For reference, here is the EDID decoded:
# edid-decode edid.bin
edid-decode (hex):
00 ff ff ff ff ff ff 00 4a 8b 7e 56 d9 05 00 00
04 12 01 03 eb 31 20 78 0a ae c5 a2 57 4a 9c 25
12 50 54 3f df 80 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 94 11 00 b0 40 58 19 20 30 20
36 00 da 28 11 00 00 18 00 00 00 0f 00 68 64 6d
69 0a 0a 0a 0a 0a 0a 0a 0a 0a 00 00 00 fd 00 38
4b 1c 53 0f 00 0a 20 20 20 20 20 20 00 00 00 fc
00 57 32 32 35 32 0a 20 20 20 20 20 20 20 00 1a
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: RTK
Model: 22142
Serial Number: 1497
Made in: week 4 of 2008
Basic Display Parameters & Features:
Digital display
DFP 1.x compatible TMDS
Maximum image size: 49 cm x 32 cm
Gamma: 2.20
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6347, 0.3417
Green: 0.2919, 0.6113
Blue : 0.1474, 0.0703
White: 0.3134, 0.3291
Established Timings I & II:
DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz
Apple : 640x480 66.667 Hz 4:3 35.000 kHz 30.240 MHz
DMT 0x05: 640x480 72.809 Hz 4:3 37.861 kHz 31.500 MHz
DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz
DMT 0x08: 800x600 56.250 Hz 4:3 35.156 kHz 36.000 MHz
DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz
DMT 0x0a: 800x600 72.188 Hz 4:3 48.077 kHz 50.000 MHz
DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz
DMT 0x0f: 1024x768i 86.958 Hz 4:3 35.522 kHz 44.900 MHz
DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz
DMT 0x11: 1024x768 70.069 Hz 4:3 56.476 kHz 75.000 MHz
DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz
DMT 0x24: 1280x1024 75.025 Hz 5:4 79.976 kHz 135.000 MHz
Apple : 1152x870 75.062 Hz 192:145 68.681 kHz 100.000 MHz
Standard Timings: none
Detailed Timing Descriptors:
DTD 1: 1024x600 60.000 Hz 128:75 37.500 kHz 45.000 MHz (474 mm x 296 mm)
Hfront 48 Hsync 32 Hback 96 Hpol N
Vfront 3 Vsync 6 Vback 16 Vpol N
Manufacturer-Specified Display Descriptor (0x0f): 00 0f 00 68 64 6d 69 0a 0a 0a 0a 0a 0a 0a 0a 0a '...hdmi.........'
Display Range Limits:
Monitor ranges (GTF): 56-75 Hz V, 28-83 kHz H, max dotclock 150 MHz
Display Product Name: 'W2252'
Checksum: 0x1a
When I connect the display to our board and check the avialable modes, the native resolution 1024x600 is missing:
# cat /sys/class/drm/card0-HDMI-A-2/modes
1280x1024
1152x864
800x600
800x600
640x480
But when I connect the display to my x86 laptop, the resolution is fine:
# cat /sys/class/drm/card0-HDMI-A-3/modes
1024x600
1280x1024
1152x864
1024x768i
1024x768
1024x768
1024x768
800x600
800x600
800x600
800x600
640x480
640x480
640x480
640x480
This is how the screen looks when the example app is running. Notice the cog in the left bottom corner is squished. It is not extremely apparent, but, if there was a big circle in the middle of the screen (as in our application), it would look like an ellipse.
Here is output of modeset, when video=HDMI-A-2:1024x600
is on kernel command line and weston was started with mode=current
Encoders:
id crtc type possible crtcs possible clones
37 0 DSI 0x00000001 0xffffffff
39 36 TMDS 0x00000002 0x00000000
Connectors:
id encoder status name size (mm) modes encoders
38 0 disconnected HDMI-A-1 0x0 0 37
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
40 39 connected HDMI-A-2 490x320 5 39
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
#0 1280x1024 75.02 1280 1296 1440 1688 1024 1025 1028 1066 135000 flags: phsync, pvsync; type: driver
#1 1152x864 75.00 1152 1216 1344 1600 864 865 868 900 108000 flags: phsync, pvsync; type: driver
#2 800x600 60.32 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
#3 800x600 56.25 800 824 896 1024 600 601 603 625 36000 flags: phsync, pvsync; type: driver
#4 640x480 59.94 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
props:
1 EDID:
blobs:
value:
04120103eb3120780aaec5a2574a9c25
010101010101941100b0405819203020
690a0a0a0a0a0a0a0a0a000000fd0038
0057323235320a20202020202020001a
2 DPMS:
flags: enum
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
values: 0 1
value: 0
4 TILE:
blobs:
value:
CRTCs:
id fb pos size
33 0 (0,0) (0x0)
#0 nan 0 0 0 0 0 0 0 0 0 flags: ; type:
props:
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
36 41 (0,0) (1280x1024)
props:
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
31 0 0 0,0 0,0 0 0x00000001
formats: XR24 AR24 RG16 XB24 AB24 AR15 XR15
props:
8 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
32 zpos:
values: 0 0
value: 0
34 36 41 0,0 0,0 0 0x00000002
props:
8 type:
value: 1
35 zpos:
values: 0 0
value: 0
Frame buffers:
id size pitch
Is there anything I could check to get the right resolution?
