Thank you for your quick reply.
This is pretty strange because when I run it manually I don’t have any error.
Using git bash I have:
rfonc@LAPTOP-LTG4PETV MINGW64 ~
$ git clone git://github.com/coreos/go-systemd.git
Cloning into 'go-systemd'...
remote: Enumerating objects: 2156, done.
remote: Counting objects: 100% (116/116), done.
remote: Compressing objects: 100% (82/82), done.
remote: Total 2156 (delta 48), reused 73 (delta 29), pack-reused 2040
Receiving objects: 100% (2156/2156), 707.46 KiB | 429.00 KiB/s, done.
Resolving deltas: 100% (1119/1119), done.
But now when I run the following command I have 4 errors now:
C:\Users\rfonc>docker run --rm -it --name=crops -v \\wsl$\Ubuntu-18.04\home\rfonck\yocto-workdir:/workdir --workdir=/workdir -e MACHINE=apalis-imx6 -e DISTRO=torizon -e IMAGE=torizon-core-docker torizon/crops:dunfell-5.x.y startup-tdx.sh
... A new version of repo (2.15) is available.
... New version is available at: /workdir/torizon/.repo/repo/repo
... The launcher is run from: /bin/repo
!!! The launcher is not writable. Please talk to your sysadmin or distro
!!! to get an update installed.
nothing to commit (working directory clean)
Build environment configured. Building target image torizon-core-docker
> DISTRO=torizon MACHINE=apalis-imx6 bitbake torizon-core-docker
Loading cache: 100% |####################################################################################| Time: 0:00:01
Loaded 3892 entries from dependency cache.
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-tdx-linux-gnueabi"
MACHINE = "apalis-imx6"
DISTRO = "torizon"
DISTRO_VERSION = "5.3.0-devel-20210622182435+build.0"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-toradex-torizon = "HEAD:ebe4f460ef1850551a4b66bf82dd480c178a93a1"
meta-toradex-distro = "HEAD:a12eef0d00f2dce08e65ac3b70075a21abc5c5dc"
meta-toradex-bsp-common = "HEAD:2c539036e3421150b29336fc926b2678df589206"
meta-oe
meta-networking
meta-filesystems
meta-python
meta-perl = "HEAD:11eae114522a6befa06c7f4021a83bc016133543"
meta-virtualization = "HEAD:92cd3467502bd27b98a76862ca6525ce425a8479"
meta-updater = "HEAD:b1bb00f4b645e7ab5cf6af4a6579df8b0f24e079"
meta-toradex-nxp = "HEAD:ce70bcafb720725ef78fb3f47c2da153372099fa"
meta-freescale = "HEAD:0173d3f8d0cbf7844a4d23bc3fb30144abc914bb"
meta-freescale-3rdparty = "HEAD:a7b96dc91bb2818d8ed8210654db10d08d4d7890"
meta-yocto-bsp
meta-poky = "HEAD:134c1e9902148f907d4f9e78435fa3a827c6df03"
meta-security = "HEAD:93232ae6d52b0d1968aa0ce69fa745e85e3bbc6b"
meta-lmp-base = "HEAD:4bc19dd07a748301bbd8314f454c35a6ceb77880"
meta = "HEAD:ecd636154e7cfc1349a7cfd8026a85eafa219535"
Initialising tasks: 100% |###############################################################################| Time: 0:00:05
Sstate summary: Wanted 1040 Found 166 Missed 874 Current 1082 (15% match, 58% complete)
NOTE: Executing Tasks
ERROR: linux-toradex-5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0 do_compile: oe_runmake failed
ERROR: linux-toradex-5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0 do_compile: Execution of '/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/temp/run.do_compile.270' failed with exit code 1:
GEN Makefile
CALL /workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/atomic/check-atomics.sh
CALL /workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/checksyscalls.sh
CHK include/generated/compile.h
CC drivers/gpu/drm/imx/ipuv3/ipuv3-crtc.o
AR drivers/gpu/drm/omapdrm/displays/built-in.a
AR drivers/gpu/drm/omapdrm/dss/built-in.a
/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/drivers/gpu/drm/imx/ipuv3/ipuv3-crtc.c: In function 'ipu_drm_bind':
/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/drivers/gpu/drm/imx/ipuv3/ipuv3-crtc.c:448:2: error: 'ret' undeclared (first use in this function); did you mean 'net'?
448 | ret = ipu_crtc_init(ipu_crtc, pdata, drm);
| net
/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/drivers/gpu/drm/imx/ipuv3/ipuv3-crtc.c:448:2: note: each undeclared identifier is reported only once for each function it appears in
AR drivers/gpu/drm/omapdrm/built-in.a
make[6]: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/Makefile.build:262: drivers/gpu/drm/imx/ipuv3/ipuv3-crtc.o] Error 1
make[5]: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/Makefile.build:496: drivers/gpu/drm/imx/ipuv3] Error 2
make[4]: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/Makefile.build:496: drivers/gpu/drm/imx] Error 2
make[4]: *** Waiting for unfinished jobs....
make[3]: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/Makefile.build:496: drivers/gpu/drm] Error 2
make[2]: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/scripts/Makefile.build:496: drivers/gpu] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/Makefile:1734: drivers] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source/Makefile:179: sub-make] Error 2
WARNING: /workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/temp/run.do_compile.270:1 exit 1 from 'exit 1'
ERROR: Logfile of failure stored in: /workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/temp/log.do_compile.270
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: KBUILD_BUILD_TIMESTAMP: Thu May 27 21:52:13 UTC 2021
| NOTE: make -j 4 HOSTCC=gcc -isystem/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/lib -L/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/lib -Wl,-rpath,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/workdir/torizon/build-torizon/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 HOSTCPP=gcc -E HOSTCXX=g++ -isystem/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/lib -L/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/lib -Wl,-rpath,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/workdir/torizon/build-torizon/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 zImage CC=arm-tdx-linux-gnueabi-gcc -mno-thumb-interwork -marm -fuse-ld=bfd -fmacro-prefix-map=/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0=/usr/src/debug/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0 -fdebug-prefix-map=/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0=/usr/src/debug/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0 -fdebug-prefix-map=/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot= -fdebug-prefix-map=/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/recipe-sysroot-native= -fdebug-prefix-map=/workdir/torizon/build-torizon/tmp/work-shared/apalis-imx6/kernel-source=/usr/src/kernel LD=arm-tdx-linux-gnueabi-ld.bfd LOADADDR=0x11000000
| GEN Makefile
| | net
| ERROR: oe_runmake failed
| ERROR: Execution of '/workdir/torizon/build-torizon/tmp/work/apalis_imx6-tdx-linux-gnueabi/linux-toradex/5.4.115+gitAUTOINC+e4c8d52727_64dbf17bb3-r0/temp/run.do_compile.270' failed with exit code 1:
| GEN Makefile
| | net
ERROR: Task (/workdir/torizon/build-torizon/conf/../../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_compile) failed with exit code '1'
WARNING: go-systemd-4+gitAUTOINC+b4a58d9518-r0 do_fetch: Failed to fetch URL git://github.com/coreos/go-systemd.git, attempting MIRRORS if available
ERROR: go-systemd-4+gitAUTOINC+b4a58d9518-r0 do_fetch: Fetcher failure: Unable to find revision b4a58d95188dd092ae20072bac14cece0e67c388 in branch master even from upstream
ERROR: go-systemd-4+gitAUTOINC+b4a58d9518-r0 do_fetch: Fetcher failure for URL: 'git://github.com/coreos/go-systemd.git'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /workdir/torizon/build-torizon/tmp/work/armv7at2hf-neon-tdx-linux-gnueabi/go-systemd/4+gitAUTOINC+b4a58d9518-r0/temp/log.do_fetch.1385
ERROR: Task (/workdir/torizon/build-torizon/conf/../../layers/meta-virtualization/recipes-devtools/go/go-systemd_git.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3994 tasks of which 3988 didn't need to be rerun and 2 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 1 seconds
Summary: 2 tasks failed:
Summary: There was 1 WARNING message shown.
Summary: There were 4 ERROR messages shown, returning a non-zero exit code.
I don’t understand why it works using git and not in the script. If you have any idea about the origin of my problem I will be very grateful.
rfonck
