I’m trying to configure a torizoncore image to make a fpga accessible as sram using eim.
I have recompiled the os with only a few changes: I allowed GONFIG_MTD_ROM, CONFIG_MTD_RAM and CONFIG_MTD_PHYSMAP using menuconfig. I have now the following configuration:
apalis-imx6-10571917:/dev$ zcat /proc/config.gz | grep MTD
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_AR7_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_OOPS=y
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
CONFIG_MTD_CFI=y
CONFIG_MTD_JEDECPROBE=y
CONFIG_MTD_GEN_PROBE=y
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_STAA=y
CONFIG_MTD_CFI_UTIL=y
CONFIG_MTD_RAM=y
CONFIG_MTD_ROM=y
CONFIG_MTD_ABSENT=y
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
CONFIG_MTD_PHYSMAP=y
CONFIG_MTD_PHYSMAP_COMPAT=y
CONFIG_MTD_PHYSMAP_START=0x8000000
CONFIG_MTD_PHYSMAP_LEN=0
CONFIG_MTD_PHYSMAP_BANKWIDTH=2
# CONFIG_MTD_PHYSMAP_OF is not set
# CONFIG_MTD_IMPA7 is not set
# CONFIG_MTD_INTEL_VR_NOR is not set
CONFIG_MTD_PLATRAM=y
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
CONFIG_MTD_DATAFLASH=y
# CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set
# CONFIG_MTD_DATAFLASH_OTP is not set
# CONFIG_MTD_MCHP23K256 is not set
CONFIG_MTD_SST25L=y
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
CONFIG_MTD_NAND_CORE=y
# CONFIG_MTD_ONENAND is not set
CONFIG_MTD_NAND_ECC_SW_HAMMING=y
# CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
CONFIG_MTD_RAW_NAND=y
# CONFIG_MTD_NAND_ECC_SW_BCH is not set
# CONFIG_MTD_NAND_DENALI_PCI is not set
# CONFIG_MTD_NAND_DENALI_DT is not set
# CONFIG_MTD_NAND_CAFE is not set
# CONFIG_MTD_NAND_BRCMNAND is not set
CONFIG_MTD_NAND_GPMI_NAND=y
# CONFIG_MTD_NAND_MXC is not set
# CONFIG_MTD_NAND_MXIC is not set
# CONFIG_MTD_NAND_GPIO is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_RICOH is not set
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_SPI_NAND is not set
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
CONFIG_MTD_SPI_NOR=y
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
CONFIG_MTD_UBI_FASTMAP=y
# CONFIG_MTD_UBI_GLUEBI is not set
CONFIG_MTD_UBI_BLOCK=y
# CONFIG_MTD_HYPERBUS is not set
CONFIG_LEDS_TRIGGER_MTD=y
I also applied a device tree overlay that enable eim and specify a sram device:
* Copyright 2020-2021 Toradex
// Enable the LVDS interface on the Apalis iMX6Q. Make sure to also select a valid display configuration.
/dts-v1/;
/plugin/;
compatible = "toradex,apalis_imx6q";
/* gpio */
&gpio6 {
gpio6 {
gpio-hog;
gpios = <9 5>;
output-high;
&gpio1 {
gpio7 {
gpio-hog;
gpios = <2 0>;
output-high;
gpio8 {
gpio-hog;
gpios = <6 0>;
output-high;
&ecspi1 {
/* pin conflict with weim */
status = "disabled";
&ecspi2 {
&can2 {
/* max7310_c on i2c3 is gone */
&i2c1 {
&i2c3 {
&uart3 {
/* pin conflict with gpmi and weim */
&uart1 {
&usbh1 {
/* max7310_b on i2c3 is gone */
&weim {
compatible = "fsl,syctrl-eim-driver";
pinctrl-names = "default";
fsl,weim-cs-gpr = <&gpr>;
ranges = <0 0 0x08000000 0x08000000>;
/* FPGA on CS0 */
sram@0,0 {
compatible = "mtd-ram";
reg = <0 0x00000000 0x00040000>;
bank-width = <2>;
fsl,weim-cs-timing = <0x00610001 0x00000000 0x0E022000
0x00000000 0x1c092480 0x00000000>;
#address-cells = <1>;
#size-cells = <1>;
Thanks to this overlay I can access correct values from my fpga by mmaping /dev/mem and reading values from 0x08000000 with devmem2.
But I would like to make this memory appearing as a separate device from the /dev/ folder, like /dev/sram for example.
It don’t seems to work with my actual config. what do you advise me to do to achieve this?
Best regards
rfonck
