torizoncore-builder --storage-directory won’t accept absolute location but requires absolute location when doing image unpack?
--------------------------------------------------------------- terminal session ------------------
$ cd tcbworkdir-imx6-5.1-build-test-0.0/
$ source tcb-env-setup.sh
You may have an outdated version installed. Would you like to check for updates online? [y/n] y
Setting up TorizonCore Builder with version 3.
Pulling TorizonCore Builder…
3: Pulling from torizon/torizoncore-builder
Digest: sha256:a6695866ca3f74a8350e7e9b2955c5c09363390b6b4f91a2d629573a8d737035
Status: Image is up to date for torizon/torizoncore-builder:3
docker.io/torizon/torizoncore-builder:3
Done!
Setup complete! TorizonCore Builder is now ready to use.
Important: When you run TorizonCore Builder, the tool can only access the files inside the current working directory. Files and directories outside of the current working directory, or links to files and directories outside of the current working directory, won’t be visible to TorizonCore Builder. So please make sure that, when running TorizonCore Builder, all files and directories passed as parameters are within the current working directory.
Your current working directory is: /home/deltamike/tcbworkdir-imx6-5.1-build-test-0.0
For more information, run ‘torizoncore-builder -h’ or go to TorizonCore Builder Tool - Customizing TorizonCore Images | Toradex Developer Center
$ ls
test-systems-config-0.0 storage tcb-env-setup.sh torizon-core-docker-apalis-imx6-Tezi_5.1.0+build.1.tar
$ torizoncore-builder --storage-directory storage images unpack torizon-core-docker-apalis-imx6-Tezi_5.1.0+build.1.tar
error: storage directory ‘storage’ is not absolute.
$ torizoncore-builder --storage-directory /home/deltamike/tcbworkdir-imx6-5.1-build-test-0.0/storage images unpack torizon-core-docker-apalis-imx6-Tezi_5.1.0+build.1.tar
error: storage directory ‘/home/deltamike/tcbworkdir-imx6-5.1-build-test-0.0/storage’ does not exist.
$ ls -ld /home/deltamike/tcbworkdir-imx6-5.1-build-test-0.0/storage
drwxrwxr-x 2 deltamike deltamike 4096 Jun 30 19:54 /home/deltamike/tcbworkdir-imx6-5.1-build-test-0.0/storage
