we were currently migrating our development system to Yocto 3.1 (dunfell)
Using the meta-toradex-nxp layer the do_install() fails:
The u-boot-nand.imx file which is stated in the machine configuration colibri-vf.conf in meta-freescale-3rdparty is not found.
I found out that in meta-toradex-nxp/recipes-bsp/u-boot/u-boot-toradex_2020.07.bb there is and additional task added for colibri-imx6ull and colibri-imx7 which does add the zero padding in the u-boot.imx file and creates the u-boot-nand.imx file.
I added that statement also for the colibri-vf machine.
index 4add74e..f965e28 100644
--- a/recipes-bsp/u-boot/u-boot-toradex_2020.07.bb
+++ b/recipes-bsp/u-boot/u-boot-toradex_2020.07.bb
@@ -38,3 +38,7 @@ do_compile_append_colibri-imx6ull () {
do_compile_append_colibri-imx7 () {
nand_padding
+do_compile_append_colibri-vf () {
+ nand_padding
Now the do_install() task of u-boot works without any errors.
Is the padding still needed for U-Boot on Colibri VF50?
Thanks in advance.
Kind regards,
Sebastian
