I need change settings before WinCE boot and it is too many options add manually.
The configblockeditor.exe is not working with VF61 so there is any other options to uplad configuration settings in one go?
It will be more easily if you will add option to upload setings (YMODEM) file by Debug port.
One more issue I add picture with my bootloader menu. I don’t know what is the message Static config block is not valid!
