I am running a qt quick application on EDT display. I have flashed the console-trdx-image with qt5 libraries. I can able to run the ui applications but not qt quick. the error is:
root@apalis-imx6:~# /opt/tab/bin/tab -platform eglfs
QML debugging is enabled. Only use this in a safe environment.
QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
[ 2914.779045] mxc_sdc_fb fb.20: 480x272 h_sync,r,l: 48,48,96 v_sync,l,u: 10,6,3 pixclock=11250000 Hz
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
QQmlApplicationEngine failed to load component
qrc:/main.qml:10 Type MainForm unavailable
qrc:/MainForm.ui.qml:2 module "QtQuick" version 2.6 is not installed
how to resolve it?
thank you in advance.
