We are using imx6 quad board, while booting board in uboot showing bad crc message…
in normal we can pass the default environment to saveenv it in the uboot. Then it’s not showing the warning message. we don’t want to use the saveenv enviornment.
we using script to boot the board so that, as per the conclusion we can extract the comman.h from .include/configs from uboot we can fix the bug so only,
If possible can you please share the dd command using to extract the bootagrs file
Sorry your requirement is not really clear to me. Are you looking for this file? It would be available in u-boot source code. Also have a look at this article.
