I use VF61 WinCE 1.2 version. I change some registry parameters. After I click the save reg button. But parameters doesn’t save.
Did you try and clear the registry and than save it again? Do the new values appear in registry but they just don’t get applied?
I had the same problem , the values appeared in registry but were not applied , what is the solution for this ?
What values? Please give us more information. Also please open new question do not use locked questions to ask new questions.
