i accidentally clear the deploy folder from yocto.
How to force only the deploy tasks?
When running bitbake target i always get the error:
ERROR: Function failed: do_imagedeploy …
| cp: cannot stat ‘/xxx/deploy/images/apalis-imx6/uImage*’: No such file or directory
( bitbake -c clean target dont help )
Best regards Lars
Hi Lars
Without trying this I guess it is only U-Boot and Kernel which are somewhat special. So you could clean them before rebuilding your image target which then would first rebuild U-Boot and Kernel and then build the image.
bitbake -c cleansstate virtual/bootloader virtual/kernel bitbake target
Max
thanks. that is the solution.
