I need some partitioning on the eMMC that supports A/B deployment for the rootfs+kernel+dtb:
partition | purpose | size | mount point
- boot | u-boot + environment | 16MiB | /uboot
- rootfs+kernel+dtb A | root file system A with kernel A and DTB A in /boot directory | 6GB | /rootfs if B inactive
- rootfs+kernel+dtb B | root file system B with kernel B and DTB B in /boot directory | 6GB | /rootfs if A inactive
- data | persistent data of rootfs+kernel A and B | 2,88GB | /data
I read the suggested answer for this related question. I think I need to change/implement the following.
- modify MBR creation and partitioning by adding the partitions ~ update.sh
- modify boot partition creation for u-boot by adding the kernel a/b and dtb a/b to the rootfs partitions a/b(instead of kernel image) ~ update.sh
- modify rootfs partition creation by adding kernel and dtb (instead of rootfs only) ~ update.sh
- create image for kernel+rootfs A and image for kernel+rootfs B (instead of single rootfs without kernel)
- implement flash option for kernel+rootfs A image and for kernel+rootfs B image in the (
run update_rootfs_kernel_A
and run update_rootfs_kernel_B
instead of run update_kernel
) ~ flash_blk.scr
- additional: modify mountpoint creation of rootfs to support 2 rootfs (instead of signle rootfs) [tegra-uboot-flasher/genext3fs.sh]
- add expansion of the rootfs A and B to their full size of the partition they live in ~ fs-init.bb
- add mounts in /etc/fstab (custom “dynamic” A and B switching ~ u-boot)
But as I do want to use Yocto (cannot use meta-toradex) it is not obvious for me how to do it actually.
Is this general procedure correct or did I miss something?
Could you get me some advice to adopt the instructions to a non-Yocto build?
Some more OTA software update specific details could pop up in this question in the future. They could be very specific to our product and would probably not be very helpful for others.
@roman.tx update.sh of Apalis_TK1_LinuxImageV2.6.1Beta2_20161122 states BOOT_START=$(expr 1024 \* 4 \* 2)
and a size of 4MiB for IMAGE_ROOTFS_ALIGNMENT. I it correct that BOOT_START=
needs to be changed to $(expr 1024 \* 2 \* 2)
? Or is this size 8 MiB? (The same needs to be considered for BOOT_SPACE which seems to be 40MiB instead of 20MiB.)
Regarding to “modify MBR creation and partitioning by adding the partitions ~ update.” I tried as follows.
I modified update.sh:
@@ -205,7 +205,7 @@
CBOOT_IMAGE=apalis-tk1.img
CBOOT_IMAGE_TARGET=tegra124
# assumed minimal eMMC size [in sectors of 512]
- EMMC_SIZE=$(expr 1024 \* 7450 \* 2)
+ EMMC_SIZE=$(expr 1024 \* 14900 \* 2)
@@ -343,17 +343,19 @@
# user area aka general purpose eMMC region:
# 0 -> IMAGE_ROOTFS_ALIGNMENT - reserved (not partitioned)
-# IMAGE_ROOTFS_ALIGNMENT -> BOOT_SPACE - kernel and other data
-# BOOT_SPACE -> SDIMG_SIZE - rootfs
+# IMAGE_ROOTFS_ALIGNMENT -> BOOT_SPACE - u-boot + u-boot environment
+# BOOT_SPACE -> ROOTFS_A_SIZE - rootfs + kernel + dtb A
+# ROOTFS_A_SIZE -> ROOTFS_B_SIZE - rootfs + kernel + dtb B
+# ROOTFS_B_SIZE -> DATA_SIZE - persistent data
-# 4MiB 16MiB SDIMG_ROOTFS
-# | IMAGE_ROOTFS_ALIGNMENT | BOOT_SPACE | ROOTFS_SIZE |
-# 0 4MiB 4MiB + 16MiB EMMC_SIZE
+# 4MiB 16MiB 6000MiB 6000MiB 2880MiB
+# | IMAGE_ROOTFS_ALIGNMENT | BOOT_SPACE | ROOTFS_A_SIZE | ROOTFS_B_SIZE | DATA _SIZE |
+# 0 4MiB 4MiB + 16MiB 20MiB + 6GiB 6,02GiB + 6GiB 14,9GiB
@@ -374,9 +376,14 @@
else
if [ "${MODTYPE}" = "apalis-t30" ] || [ "${MODTYPE}" = "apalis-tk1" ] || [ "${MODTYPE}" = "colibri-t30" ] ; then
# Boot partition [in sectors of 512]
- BOOT_START=$(expr 4096 \* 2)
- # Rootfs partition [in sectors of 512]
- ROOTFS_START=$(expr 20480 \* 2)
+ BOOT_START=$(expr 1024 \* 4 \* 2)
+ # Rootfs A partition [in sectors of 512]
+ ROOTFS_A_START=$(expr 1024 \* 20 \* 2)
+ # Rootfs B partition [in sectors of 512]
+ ROOTFS_B_START=$(expr 1024 \* 6020 \* 2)
+ # Data partition [in sectors of 512]
+ DATA_START=$(expr 1024 \* 12020 \* 2)
@@ -385,11 +392,14 @@
# Initialize a sparse file
dd if=/dev/zero of=${BINARIES}/mbr.bin bs=512 count=0 seek=${EMMC_SIZE}
${PARTED} -s ${BINARIES}/mbr.bin mklabel msdos
- ${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary fat32 ${BOOT_START} $(expr ${ROOTFS_START} - 1 )
- # the partition spans to the end of the disk, even though the fs size will be smaller
- # on the target the fs is then grown to the full size
- ${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary ext2 ${ROOTFS_START} $(expr ${EMMC_SIZE} \- ${ROOTFS_START} \- 1)
- ${PARTED} -s ${BINARIES}/mbr.bin unit s print
+ ${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary fat32 ${BOOT_START} $(expr ${ROOTFS_A_START} - 1 )
+ # the partition of rootfs+kernel+dtb A and B are greater than the fs size
+ # on the target the file systems are then grown to the full size of the partitions
+ ${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary ext3 ${ROOTFS_A_START} $(expr ${ROOTFS_B_START} \- 1)
+ ${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary ext3 ${ROOTFS_B_START} $(expr ${DATA_START} \- 1)
+ ${PARTED} -a none -s ${BINARIES}/mbr.bin unit s mkpart primary ext3 ${DATA_START} $(expr ${EMMC_SIZE} \- 1)
+ #${PARTED} -s ${BINARIES}/mbr.bin set 1 boot on
+ ${PARTED} -s ${BINARIES}/mbr.bin unit GiB print
I created the TFTP update media using:
./update.sh -c -m 2 -o /srv/tftp/
Powered the board on and interrupted the autoboot.
Updated the flash scripts and flashed the MBR into the eMMC:
Apalis TK1 # run setupdate
Apalis TK1 # run update_1
I checked the partition table:
Apalis TK1 # mmc dev 0 0
Apalis TK1 # mmc part
Partition Map for MMC device 0 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 8192 32768 000a7e26-01 0c
2 40960 12288000 000a7e26-02 83
3 12328960 12288000 000a7e26-03 83
4 24616960 5898240 000a7e26-04 83
I did a full update:
and rebooted…:
Apalis TK1 # boot
…into Angström (no password):
apalis-tk1 login: root
root@apalis-tk1:~#
Does that make sense or do you see some issues (something missing or not correct)?
