I try to compile v2.7 bsp but meet compile error of lxterminal.
make[2]: Entering directory '/mnt/disk/v2.7/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/lxterminal/git-r0/build/man'
| Error: you need to run configure with '--enable-man'
| in order to regenerate man pages.
| Makefile:535: recipe for target 'lxterminal.1' failed
Follow the ‘Failing Builds’ recommendations, e.g. bitbake the angstrom-lxde-image with -k again. The missing dependency will be built in the first run by some other recipe and the second run will then be able to compile lxterminal.
Build the missing dependency before building the image with ‘bitbake xmlto-native’
Update meta-lxde to include the fix ‘lxterminal: really add missing dependency to regenerate man’
I’ve the same problem, but even with the updated meta-lxde layer I have the error.
Could there be another package missing, perhaps on the host machine which still causes this error?
