VF61 WINCE 6.0 Release V1.3 Ethernet issue Connection Failure after 2 ~3 days of ideal time .After reset it recovers.
Even ping command does not work.
Could you please try with out latest image? 1.4beta2? You can download of from here → VF50 / VF61 WEC Software | Toradex Developer Center
Did you also observe the same on WEC7?
Do you run any application or do you have only empty system and it crashes? Is there any information on debug output?
Thanks for the reply
We are using wince6.0 only our application is running all other pheripherals (i2c,uart,io’s etc) are working only Ethernet not responding.
Does it also crash if your application is not running? Can you verify that it will crash when you are using CE7.
