I would like to enable FTRACE on the colibri-imx7 on the console-trdx-image. Initially I tried to add the “tools-profile” to the EXTRA_IMAGE_FEATURES as described here:
However the recipe didn’t provide anything to build tools-profile for the console image. I then tried modifying the kernel configuration manually to have the proper flags, something approximatly like this:
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_TRACING=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
# CONFIG_FUNCTION_TRACER is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_SCHED_TRACER is not set
CONFIG_ENABLE_DEFAULT_TRACERS=y
# CONFIG_FTRACE_SYSCALLS is not set
# CONFIG_TRACER_SNAPSHOT is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_UPROBE_EVENT is not set
# CONFIG_PROBE_EVENTS is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_TRACE_ENUM_MAP_FILE is not set
Unfortunately the kernel that I built doesn’t populate the tracing directory in /sys/kernel/debug.
I issued the following commands to build the manually configured kernel:
Also make sure that your kernel config changes are actually picked up. Check the output of
root@colibri-imx7:~# zcat /proc/config.gz | grep -i "trace"
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
# CONFIG_TREE_RCU_TRACE is not set
CONFIG_TRACEPOINTS=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
# CONFIG_FENCE_TRACE is not set
# CONFIG_TRACE_SINK is not set
CONFIG_TRACE_IRQFLAGS=y
CONFIG_STACKTRACE=y
# CONFIG_RCU_TRACE is not set
CONFIG_NOP_TRACER=y
CONFIG_TRACER_MAX_TRACE=y
CONFIG_GENERIC_TRACER=y
CONFIG_FTRACE=y
CONFIG_FUNCTION_TRACER=y
CONFIG_FUNCTION_GRAPH_TRACER=y
CONFIG_IRQSOFF_TRACER=y
CONFIG_SCHED_TRACER=y
CONFIG_FTRACE_SYSCALLS=y
CONFIG_TRACER_SNAPSHOT=y
CONFIG_TRACER_SNAPSHOT_PER_CPU_SWAP=y
CONFIG_STACK_TRACER=y
CONFIG_BLK_DEV_IO_TRACE=y
CONFIG_DYNAMIC_FTRACE=y
CONFIG_FTRACE_MCOUNT_RECORD=y
# CONFIG_FTRACE_STARTUP_TEST is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
I have been unable to replicate this. The built image never has ftrace enabled. I only end up with the following in /proc/config.gz:
CONFIG_STACKTRACE=y
# CONFIG_FTRACE is not set
I wrote a simple script to hopefully produce the same build process each time.
#!/bin/bash
# Needed to build the menu config
sudo apt-get install libncurses5-dev
rm -rf oe-core
mkdir oe-core
cd oe-core
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.7
repo sync
. export
# Replace the machine line
sed -i "s/\(MACHINE ?= \"colibri-t20\)\"/#\1/g"
# Dump in the stuff that we want
cat <<EOT >> conf/local.conf
MACHINE ?= "colibri-imx7"
ACCEPT_FSL_EULA = "1"
INHIBIT_PACKAGE_STRIP = "1"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
INHERIT += "buildhistory"
EOT
# Build everything
MACHINE=colibri-imx7 bitbake -c menuconfig virtual/kernel
MACHINE=colibri-imx7 bitbake -f -c compile virtual/kernel
MACHINE=colibri-imx7 bitbake console-trdx-image
The Linux banner at the very beginning contains a date/time stamp when it was compiled, that gives you a hint whether you are really booting that latest kernel you just built. Use dmesg | head.
