Hello ,
I try to install the uvc driver for win ce 5 on a old gps ( acer v200 ). I put the file in a new folder ( flashdisk ) and the install do correctly. But when i want to launch i have this error message:
“Can’t open uvc driver, error code 55 , the camera is plugged in ?”
i test my camera and that works on my pc.
I see one problem : when i want to connect my gps and my pc i see only sd card. it’s not possible to connect directly with the gps ( windows ce 5 ).
But maybe the’re is a solution?
Thank you in advance for yours advises.
