Colibri PXA300
Not Recommended for New Design (NRND), please check PCN
Colibri PXA300 is an ultra low cost SODIMM sized computer module which is part of the comprehensive Colibri product family. It is based on the Marvell/Intel Arm® XScale®PXA300 (Monahans) embedded microcomputer and runs at 208MHz. The module comes with a pre-installed and fully licensed WinCE 5/6 core OS. Linux is also available.
Colibri PXA300
Highlights
Ultra Low Cost Connectivity - Marvell XScale® PXA300 with 208MHz
Colibri PXA300 208MHz (XT) is an ultra low cost SODIMM sized computer module which is part of the comprehensive Colibri product family. It is based on the Marvell/Intel Arm® XScale®PXA300 (Monahans) embedded microcomputer and runs at 208MHz. The product targets cost sensitive applications where connectivity and standard operating systems are essential. The  PXA300 processor's power consumption is optimized using the Intel Wireless Speedstep® Technology. Colibri modules feature state of the art technology, aiming at low power systems that require high CPU performance. They also provide all the interfaces needed in a modern embedded device. There are two versions available, the Colibri PXA300 208MHz and an extended version, the Colibri PXA300 208MHz XT. In addition to all of the features of Colibri PXA300 208MHz, the XT version offers audio, touch, and analog-input functionality and is qualified for extended temperatures ranging  from -25°C to +85°C.
Besides the internal Flash memory, there additional interfaces available for data storage: USB-Memory Stick and SD Card.
Colibri modules provide glueless connectivity to passive and active LCDs with resolutions of up to 1024x768. Colibris can directly connect to a CMOS camera sensor.
In addition Colibris offer 100 MBit Ethernet as well as USB host and USB device functionality.
Flexibility and Scalability
Colibris can be scaled to meet specific cost requirements.
The entire CPU bus is available for custom extensions, such as special interfaces for high bandwidth applications.
Colibris come with a pre-installed Windows CE operating system and state of the art development tools that allow for an easy customization of the system to make it fit specific needs (e.g. LCD settings & timings, integration of customer software and the auto-start option at startup).
Latest Information on Colibri PXA300
You can find the latest information on Colibri PXA300 at the Toradex Developer Center.
Operating Systems
Windows
Windows Embedded Compact
Windows Embedded CE 6.0 is supported on Colibri PXAxxx modules. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Get Started
Carrier Boards
Learn more about SBCs and Carrier Boards
Colibri Evaluation Board
Datasheet
Iris Carrier Board
Datasheet
Viola Carrier Board
Datasheet
Supported Modules
USB 2.0
Ethernet
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
JTAG
Entire Colibri Family
4x Host, 1x OTG/Client
10/100 Mbit
Up to 32 Bit
4x
4x
2x RS232, 1x RS422/485
1x
4x
up to 158
4x
1x 4 Bit
1x
Yes
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
2x Host, 1x Client (Shared)
10/100 Mbit
1x
1x
3x /
3x TTL
4x
up to 35
4x
1x 4 Bit (microSD)
Switches
LEDs
6x
4x
LVDS
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Camera Parallel Interface
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
1x Single Channel
1x (Through DVI-I connector)
1x
1x (18 Bit/24 Bit)
Adapter required
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (18 bit)
Adapter required
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
1x
Mating Power Plug (for X33)
24-way FFC 100mm (for X6)
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
1x (*Not Assembled) /
1x
Yes
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 5A
3.3V 5A
200 x 200 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
5V DC +/- 5%
5V (External)
3.3V 3A
74 x 74 mm
-40° to 85° C
Intended Use
Pricing
Minimum Product Commitment
For Evaluation/Development
1 : $220.00
For End Products
1-99 : $73.50
100-249 : $70.55
250-499 : $66.15
500-999 : $63.20
>999 : RFQ
2030
For End Products
1-99 : $32.50
100-249 : $31.20
250-499 : $29.25
500-999 : $27.95
>999 : RFQ
2034+
Accessories
Colibri Fasteners
Analogue Camera Adapter
Carrier Board Accessory Kit
Have a Question?
