NXP® i.MX 8QXP Computer on Module
Colibri iMX8X
  • Up to 4x Arm® Cortex-A35 cores and 1x Cortex-M4 core
  • NXP® i.MX 8QuadXPlus (i.MX 8QXP), i.MX 8DualXPlus (i.MX 8DXP), i.MX 8DualX (i.MX 8DX)
  • Advanced hardware security and safety features
  • Dual Band 2.4/5 GHz 2x2 Wi-Fi 5 (802.11ac) + Bluetooth 5.3
  • Free OTA Update Solution
  • Linux OS Support included
NXP Platinum Partner - Toradex Colibri iMX8X
  • Wifi
  • Bluetooth
  • yocto
  • Torizon
  • Linux
Highlights
Power efficiency
Up to four Cortex-A35 applications cores — the most power-efficient application Arm processor to support 32- and 64-bit code execution.
Advanced safety
ECC (Error Correction Code) memory increases the reliability and safety of the system. The Colibri IMX8X has ECC-protected internal memory (TCM) in the SoC and CPU Caches. The internal memory is tightly coupled (TCM) with the Cortex-M4 core to provide a protected environment for software running the M4 microcontroller.
Torizon for Remote Updates and Fleet Monitoring
Ready for Hard-Real-Time
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4F processors for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
High-performance, pre-certified Wi-Fi and Bluetooth
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multi-antenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
Rugged and Reliable
Each module comes with environmental test reports for vibration and EMI/EMC to give you peace of mind. These modules are built with highly reliable eMMC flash memory, and tools like the Toradex Flash Analytics tool allow you to monitor flash wear in a simple manner.
Toradex Colibri Computer Module Family
Carrier boards designed for the Colibri iMX8X are not just compatible between the four Colibri iMX8X modules — in fact, they are compatible with the complete Colibri family, including the NXP i.MX 7, i.MX 6ULL, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. Currently, there are eight different modules with over 20 variations available. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
Operating Systems
Toradex offers free support and maintenance for embedded Linux and FreeRTOS on the NXP i.MX 8X-based Colibri iMX8X SoMs. This allows system designers to focus on the application only, instead of focusing also on the OS and low-level device drivers. Other OS such as Android are supported by ourpartners.
Torizon Embedded Linux OS
FreeRTOS
Toradex provides direct support for FreeRTOS on Colibri iMX8X and Colibri. FreeRTOS is a real-time OS that runs on the Cortex-M4 cores in parallel to the main OS.
Android
Android on Colibri iMX8X is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds.
Features
High-speed dual-band 802.11ac
2x2 MU-MIMO Wi-Fi and Bluetooth 5
Quad Arm Cortex-A35 @ 1.2GHz
Single Arm Cortex-M4F @ 266MHz
Vivante GC7000Lite
Up to 2GB LPDDR4 RAM
Second RGMII interface - dual Ethernet
Integrated PMIC
Single 3.3V power supply
FRONT
Dedicated MIPI DSI/LVDS
interface
Dedicated quad-lane
MIPI CSI-2 interface
Industrial-grade flash memory
- 8GB eMMC
BACK
CPU Name NXP® i.MX 8X
CPU Type 4x Arm® Cortex™-A35
Microcontroller 1x Arm® Cortex™-M4F
CPU Clock Up to 1.2 GHz (A35)
266 MHz (M4F)
Floating Point Unit VFPv4
Arm® NEON™ Yes
L1 Instruction Cache 32KB (A35)
16KB (M4F)
L1 Data Cache 32KB (A35)
16KB (M4F)
L2 Cache 512KB (A35)
RAM Up to 2GB LPDDR4 (32 bit)
Flash Up to 8GB eMMC
USB 2.0 1x Host / 1x OTG
Ethernet 10/100 MBit/s with AVB (+2nd RGMII/RMII)
I2C 8x
SPI 3x
QSPI 2x
UART 5x
PWM 10x
GPIO 97x
Analog Input 4x
SDIO/SD/MMC 1x
CAN 3x
Display Controller Single
Graphics Controller Vivante GC7000Lite
Resistive Touch 1x (4-wire)
Parallel RGB LCD 1x (up to 1280 x 720 x 24bpp)
LVDS 2x single channel 85 Mpixel/s or 1x dual channel 170 Mpixel/s
Up to 1920x1200x24bpp at 60fps
(via on-module FFC connector)
Display Serial Interface 2x quad-lane MIPI/DSI
Digital Audio 4x SAI: I2S or AC97
Analog Audio Line in 1x (Stereo)
Analog Audio Mic in 1x (Mono)
Analog Audio Headphone out 1x (Stereo)
Parallel Camera Interface 1x (up to 10 bits)
Size 67.6 x 36.7 x 6.2 mm
Temperature -40° to 85° C(1)
Power Dissipation TBD
Product Availability 2035+
Guide Me
Configure Colibri iMX8X
Let’s Go
Colibri iMX8 QuadXPlus
2GB Wi-Fi / Bluetooth IT
PN: 0038
Colibri iMX8 QuadXPlus 2GB Wi-Fi / Bluetooth IT
  • A35
  • A35
  • A35
  • A35
  • M4F
  • 3D GPU
  • VPU
  • 2GB RAM
  • 8GB FLASH
  • -40° to 85° C
2GB IT
PN: 0050
Colibri iMX8 QuadXPlus 2GB IT
  • A35
  • A35
  • A35
  • A35
  • M4F
  • 3D GPU
  • VPU
  • 2GB RAM
  • 8GB FLASH
  • -40° to 85° C
Colibri iMX8 DualX
1GB Wi-Fi / Bluetooth
PN: 0051
Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth
  • A35
  • A35
  • M4F
  • 3D GPU
  • VPU
  • 1GB RAM
  • 4GB FLASH
  • -25° to 85° C
Colibri iMX8 DualX
1GB
PN: 0052
  • A35
  • A35
  • M4F
  • 3D GPU
  • VPU
  • 1GB RAM
  • 4GB FLASH
  • -25° to 85° C
Configure Your Own Colibri iMX8X
Colibri iMX8X
1x Arm Cortex™-M4F
Guide Me
Get Started
Colibri iMX8X Evaluation Kit
$613.65
  • Four Cortex-A35 1.2 GHz processor
  • NXP i.MX 8X applications processor
  • Parallel RGB or VGA (via converter) up to 1280 x 720 x 24bpp
Buy Now
Colibri iMX8X Evaluation Kit 2
$434.65
  • Parallel RGB or VGA VGA (via converter) up to 1280 x 720 x 24bpp
  • Arduino Uno and Raspberry Pi Compatible Pin Headers
Buy Now
Carrier Boards
Learn more about SBCs and Carrier Boards
Colibri Evaluation Board
Datasheet
Iris Carrier Board
Datasheet
Viola Carrier Board
Viola Datasheet
Colibri Partner Carrier Boards
Supported Modules
USB 2.0
Ethernet
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
JTAG
Entire Colibri Family
4x Host, 1x OTG/Client
10/100 Mbit
Up to 32 Bit
4x
4x
2x RS232, 1x RS422/485
1x
4x
up to 158
4x
1x 4 Bit
1x
Yes
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
2x Host, 1x Client (Shared)
10/100 Mbit
1x
1x
3x /
3x TTL
4x
up to 35
4x
1x 4 Bit (microSD)
10/100 Mbit
1x
1x
2x TTL, 1x USB-UART
4x
up to 39
4x
1x 4 Bit (SD/MMC)
Yes
up to 4x Host
up to 2x 10/100 MBit
1x
1x
1x RS-422, 1x RS-485
up to 4x
up to 24x
up to 4x
1x
Up to 2x
Switches
LEDs
6x
4x
up to 3x
LVDS
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Camera Parallel Interface
Analog Audio Mic in
1x Single Channel
1x (Through DVI-I connector)
1x
1x (18 Bit/24 Bit)
Adapter required
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (18 bit)
Adapter required
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (Shared with RGB)
1x (18 bit)
Yes
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x
1x
1x
1x
up to 4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
Type Specific Board Connector
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
1x
Mating Power Plug (for X33)
24-way FFC 100mm (for X6)
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
1x (*Not Assembled) /
1x
Yes
1x
1x
Yes
1x
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 5A
3.3V 5A
200 x 200 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
5V DC +/- 5%
5V (External)
3.3V 3A
74 x 74 mm
-40° to 85° C
5V DC +/- 5%
3.3V 3A
100 x 80 mm
-25° to 85° C
5-36V DC
-40° to 85° C
Intended Use
Pricing
Minimum Product Commitment
For Evaluation/Development
1 : $229.00
For End Products
1-99 : $79.95
>99 : RFQ
2030
For End Products
1-99 : $33.60
>99 : RFQ
2034+
1 : $69.90
Accessories
Colibri Fasteners
Resistive Touch Display 7" Parallel
  • No special drivers required
Capacitive Touch Display 7" Parallel
  • Atmel touch driver
LM816 USB WiFi
Carrier Board Accessory Kit
  • Cable length: 100mm
  • Manufacturer: Unictron
  • Manufacturer: Chang Hong
  • Reference: DA-2458-02
Pigtail Antenna Cable MHF4 to RP-SMA 100mm and 200mm
  • Cable length: 200mm
  • Suitable for outdoor-usage (IP67)
DSI to HDMI Adapter
  • Connects directly to the HDMI FFC receptacle of the Colibri Evaluation Board, Iris or the Colibri HDMI Adapter
Ecosystem
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX8X and choose an OS!
Learn More
Easy-to-use Rich Graphical User Interfaces
The Colibri iMX8X provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt
Crank Storyboard
Get started with Crank Storyboard
DiSTI GL Studio
The Colibri iMX8X is ideal for critical applications where safety and reliability are key. These are also the key focus areas for DiSTI’s GL Studio.
Get started with DiSTI GL Studio
Edge Computing
AWS IoT Greengrass
AWS provides a wide range of services to help you build scalable industrial IoT solutions. AWS IoT Greengrass is a key tool that runs directly on the Toradex SoM. Currently AWS, NXP and Toradex collaborate closely.
Get started with AWS SageMaker Neo
Industrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX8X is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
Get started with CODESYS on Torizon
Matrikon OPC UA
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX8X perfectly. You can integrate it yourself, or leverage the expertise of our partner, BE.services, to outsource integration.
Watch our webinar with BE.services
Roadmap
Min. Product Commitment
As per NXP Roadmap
2035+
Hardware Roadmap
  • 2024
  • 2025
  • 2026
  • 2027
  • 2028
  • 2029
  • 2030
0038 Colibri iMX8QXP 2GB WB IT
0050 Colibri iMX8QXP 2GB IT
0051 Colibri iMX8DX 1GB WB
0052 Colibri iMX8DX 1GB
  • In Development
  • Sample Production
  • Volume Production
Software Support Status
For latest news release refer
Linux BSP | Torizon OS BSP
Have a Question?
