SMARC Family
Toradex Quality for the SMARC Ecosystem
The Toradex SMARC Family brings the trusted well-known Toradex quality, reliability, and ease-of-use to the SMARC (Smart Mobility Architecture) standard. Toradex SMARC reduces the total cost and project risks by reducing the development and maintenance efforts for software and hardware, all while leveraging the existing SMARC ecosystem you are familiar with.
Upcoming Webinar
SMARC Family
Why Toradex SMARC
Toradex Quality on SMARC
Enjoy Toradex’s well known quality, reliability, and ease-of-use that lower your total cost-of-ownership.
Learn more
Industry-Leading Linux Support
Toradex provides best-in-class Linux support, including long-term support (LTS). Our focus on Linux Mainline LTS releases, combined with our Upstream First strategy, and rigorous, automated software testing, lets you to fully focus on your application.
Integrated Secure Remote Updates
Torizon embedded Linux system has integrated Over the Air (OTA) Updates, Health Monitoring, and Remote Updates for easy troubleshooting.
Fully SMARC-Compliant
Be fully compatible with SMARC (Smart Mobility Architecture) and leverage the extensive carrier board ecosystem. Toradex SMARC Module is built according to the latest SMARC 2.2 and is compatible with most SMARC 2.1/2.0 carrier boards.
Free Compatibility Check
Comply with the EU Cyber Resilience Act (CRA)
Torizon and Toradex simplify compliance with CRA. Including CVE Monitoring, SBOMs, Secure Boot, Encryption, Secure Remote Updates, and much more.
Learn More
Free Maintenance - Lowest Total Cost
Leave the harder aspects of long-term maintenance to us, and benefit from 10+ years of great software and hardware support on your SMARC Module. Enjoy our best-in-class customer support, and access to our vast developer resources for self-service support.
Learn More
Reliable Supply Chain
Enjoy peace of mind with our proven track record of dependable availability and timely delivery, even in challenging circumstances, for over 20 years.
Learn More
Migrate To Toradex SMARC
Do you already have a SMARC Module and want to leverage Toradex's unique offerings to lower your total cost of ownership and obtain better supply security? The Toradex SMARC family maximizes compatibility with a wide range of other SMARC providers, making it quick and easy to migrate your project to Toradex’s SMARC!
Check your Carrier Board Compatibility
While SMARC is a standard used by many different companies, there can be variations in each vendor’s pin-out. Toradex SMARC products maximize compatibility with a wide range of other providers!
Simple Migration of Your Software
Toradex simplifies the migration of your existing Linux software or from Windows to Linux. Toradex-built Torizon, is an industrial Linux that is very easy to use, and even allows seamless migration from Windows. For example, you can still use Visual Studio Code, .NET, and more. Additionally, Toradex provides migration services.
Free Migration Effort Estimation
Get Built-in OTA Updates, Security Compliance, and More
After migration, you will have reliable hardware, industry-leading customer support, and a secure Linux software stack ready to comply with Cybersecurity regulations. This includes mandatory features like Secure Boot, OTA Updates, Remote Access, Device Management and more!
Typical Migration Effort
From the same SoC
2 weeks
From other ARM SoC
4 weeks
From x86 SoC
8 weeks
Need more? We can help!
Let us review your current carrier board and software, and we’ll show you how easy it is to migrate to Toradex SMARC.
Carrier Board compatibility check, migration guidance, tips and tricks
Product changes and complete development and manufacturing of carrier boards
Best practices for Software Migration, how Torizon helps, guidance when migrating from x86 or other ARM-based SMARC
Is SMARC For Me?
Being a standard designed to accommodate a wide range of ARM and X86 Systems-on-Chip, SMARC made tradeoffs to prioritize broad compatibility over cost, size, and performance. If the wide compatibility and the second source are not the top priority, our other families are typically the better product fit.
SMARC
Wider Range of x86/ARM SoCs
SMARC supports many ARM and x86 SoCs. SMARC System on Modules are available from a wide range of vendors.
Optimized for Compatibility
SMARC, with its broad standard, is designed to accommodate a wide range of use cases, supporting both ARM and x86 chips. This versatility means it may not be as finely tuned for specific applications.
Other Toradex Families
Better Optimized for ARM
Toradex’s other families are purpose-built for ARM systems, designed to operate within a precise power and performance range. This results in a system that is fine-tuned to a use case much closer to your needs.
Optimized for Scalability and Cost
Thanks to better optimization, our other families offer a superior value-to-cost ratio and lower indirect costs. For example, developing a carrier board for Verdin is much simpler than for SMARC.
Better HW/SW Compatibility
As part of our in-house standards, we guarantee true hardware and software compatibility within members of the same family. Easily scale up or down in performance without losing any work.
Toradex-Focused Standard
While Toradex SoM families are available off-the-shelf exclusively from Toradex, the form factor specification is open, allowing any company to manufacture pin-compatible modules and reduce vendor lock-in.
SMARC Computer on Modules Family
  • A53
  • A53
  • A53
  • A53
  • M7
  • 3D GPU
  • NPU
  • ISP
  • 4GB RAM
  • 32GB FLASH
  • A55
  • A55
  • A55
  • A55
  • A55
  • A55
  • M7
  • M33
  • 3D GPU
  • NPU
  • ISP
  • 16GB RAM
  • 128GB FLASH
Software
Torizon Linux Platform
Torizon is a Linux-based software platform ideal for industrial, medical, and other highly-reliable scenarios. It is a developer-friendly ecosystem that simplifies the process of developing and maintaining embedded software.
Toradex carries out in-house development and maintenance of a Yocto Project-compatible production-quality Embedded Linux BSP.
SMARC Computer on Modules - Comparison Table
SMARC iMX8M Plus
SMARC iMX95
Datasheet - Contact Us
Details
CPU Name
CPU Type
Microcontroller
CPU Clock
NXP® i.MX 8M Plus
4x Arm Cortex™-A53
1x Arm Cortex™-M7
1600MHz (A53)
800MHz (M7)
NXP® i.MX 95
6x Arm Cortex™-A55
1x Arm Cortex™-M7
1x Arm Cortex™-M33
1800MHz (A55)
800MHz (M7)
333MHz (M33)
RAM
Flash
4GB LPDDR4 (32 bit)
32GB eMMC
16GB LPDDR5 (32-bit)
64GB eMMC
USB 3.2
USB 2.0
Ethernet
xGMII (for additional Ethernet)
Wi-Fi
Bluetooth
PCIe
I2C
SPI
UART
PWM
SDIO/SD/MMC
CAN FD
2x Host (Gen1)
2x Host / 1x OTG
2x Gigabit (1x PHY with TSN + 1x RGMII)
2.4/5 GHz Dual Band 2x2 Wi-Fi 5 (802.11ac)
Bluetooth 5.3
1 (x1 Gen 3)
5x
2x
4x
1x
1x
2x
2x Host (Gen1)
2x Host / 1x OTG
2x Gigabit with TSN
1x 10 Gigabit with TSN
2.4/5 GHz Dual-band 1x1 Wi-Fi 6 (802.11ax)
Yes, 5.2
2 (x1 Gen 3)
5x
2x
4x
3x
1x
2x
Neural Processing Unit (NPU)
Image Signal Processor (ISP)
Display Controller
Video Decoder
Video Encoder
Display Serial Interface
LVDS
HDMI
Digital Audio
2D Acceleration
3D Acceleration
Display Port
Camera Serial Interface
Yes (2.3 TOPS)
1x
Triple
Yes (H.264/AVC and H.265/HEVC)
1x Quad Lane MIPI DSI (up to 1920x1080)
1x (up to 1920x1080)
1x (up to 4k)
2x I2S
Yes
Yes
1x Quad Lane MIPI CSI-2 + 1x Dual Lane MIPI CSI-2
Yes (2.0 TOPS)
1x
Single (Dual Engine)
1x Dual Channel (up to 1920x1080)
2x I2S
Yes
Yes
1x (up to 4k)
Torizon
Embedded Linux
Preinstalled OS
Android
QNX
FreeRTOS
Q1 2025
Q1 2025
Toradex Easy Installer (Q1 2025)
Coming Soon
Q1 2025
Q1 2025
Coming Soon
Size
Temperature
Shock / Vibration
Power Dissipation
82 x 50 mm
-40° to 85° C
TBD
82 x 50 mm
-40° to 85° C
TBD
General: Some interfaces are available on pins that are not entirely compatible within the SMARC Computer on Module family. There are restrictions to using different interfaces simultaneously, please check the respective datasheet for exact details.
SMARC Carrier Boards
SMARC Development Board
The SMARC Development Board is a fully featured carrier board providing easy access to all features of the SMARC family. Several display adapter boards will be available to support HDMI, LVDS and DSI interfaces (a DSI to HDMI Adapter is included with SMARC Development Boards).
Toradex System on Modules - Performance Comparison
Toradex offers a wide range of System on Modules across various product families, designed to meet our customers' needs in applications requiring high performance, industrial reliability, and safety. Our solutions deliver both cost-effectiveness and high performance, when compared to alternatives like x86 devices and other proprietary GPU-accelerated hardware.
The result is focused on CPU Performance.
These results are estimates, and performance may vary depending on your specific use case. For a personalized performance comparison, contact us today!
Other Computer on Module Families
Aquila Arm® Family
Aquila is a new System on Module standard expanding the Toradex portfolio to new heights, offering unparalleled performance for computationally intensive CPU, machine learning, and vision workloads.
Verdin Arm® Family
Verdin Arm family Computer on Modules (CoMs) combine modern high-speed interfaces, an intuitive pinout and a compact form factor into a scalable, pin-compatible, cost and power-optimized offering. Includes free Operating System support for Embedded Linux
Apalis Arm® Family
Apalis Arm family Computer on Modules (CoMs) offers advanced computing with supreme graphics at optimal power consumption, along with support of high speed interfaces and extensive multimedia formats. Includes free Operating System support for Embedded Linux and Windows Embdded Compact
Colibri Arm® Family
Colibri Arm family offers an extensive portfolio of pin-compatible System on Modules(SoMs). These SoMs have small form factor, complemented with the presence of many industrial and connectivity interfaces. Includes free Operating System support for Embedded Linux and Windows Embdded Compact
Have a Question?
