Highlights
Featuring up to six ARM Cortex-A55 cores as well as an independent safety domain consisting of high-performance ARM Cortex-M7 and ARM Cortex-M33 cores, the Verdin iMX95 SoM combines low-power, real-time and high-performance processing. Additionally, support for LPDDR5 RAM delivers the highest bandwidth for demanding Computing, Graphics, and Machine Learning applications.>
The Verdin iMX95 SoM offers an ARM Mali GPU, enabling rich, high-resolution graphical experiences with hardware acceleration. Additionally, Toradex partners with the Qt Company, Crank Software, Slint and others to provide optimized UI frameworks, so you can get your product to market faster.
The integrated neural network processing unit (NPU) accelerates inference performance for Machine Learning applications, outperforming the Verdin iMX8M Plus’s NPU by a factor of 2 (on our benchmarks). Toradex provides integration with popular machine learning frameworks, such as TensorFlow, to make it easy to get started developing your AI-based products.
The Verdin iMX95 SoM is an affordable approach to the i.MX95 SoC, enabling your product to leverage this powerful chip without losing performance and speed, while keeping costs to a minimum.
The Verdin iMX95 supports the implementation of security-critical functions like secure boot, cryptography, trust provisioning, and run-time attestation, and simplifies compliance with global Cyber security regulations, such as the upcoming EU Cyber Resilience Act (CRA). Torizon goes further and streamlines the implementation process, so you can go to market faster.
Designed and manufactured for high reliability in harsh, demanding environments, and in a wide temperature range, the Verdin iMX95 SoM is made for industry-critical applications.
The Verdin iMX95 System-on-Module is available with a tightly integrated Torizon Cloud, which accelerates the development and maintenance of your products. Some key features include highly secure and reliable, remote and offline updates, fleet monitoring and remote access.
Torizon
The Road to Verdin iMX95
As NXP partner and exclusive i.MX 95 Alpha Program participant, Toradex is the first to bring the i.MX95 to customers with the i.MX95 Verdin EVK. We also provide the natural path for scaling to production from the EVK, the Verdin iMX95 System-on-Module!
Start with the
i.MX95 Verdin EVK
Use the i.MX95 Verdin EVK to kick off your development work right away. Switch to the Verdin iMX95 System on Module to get your product ready for mass production
Start with the
Verdin iMX8M Plus
Thanks to compatibility, you can develop and test your carrier board with any Verdin System on Modules, including the Verdin iMX8M Plus. Or, even simpler, opt for a proven Verdin Carrier Board and simply upgrade to the Verdin iMX95.
Need more options?
Toradex offers alternative approaches to the i.MX95 SoC, on other form factors timelines, and even allows for your specific customization or chip-down design.
Start with the i.MX95 Verdin EVK Today!
Operating Systems
Torizon makes modern, iterative product development easier by seamlessly integrating hardware, an OS, development tools, remote updates, and fleet monitoring. That makes it a scalable solution for devices requiring high reliability and security.
Torizon accelerates your iMX95 project. The ready and maintained embedded Linux OS with simple tools allows you to focus on your application. Torizon is built with Continuous Delivery in mind, so you can ship early and update iteratively. Secure and Reliable Built-in Remote Updates, Device Monitoring, and Remote access reduces your risk. It lets you detect issues before they get serious, debug devices in the field, and take action. Torizon also makes it easy to comply with new regulations like the EU Cyber Resilience Act.
Get an Overview For Application Developer For Tech LeadsWe wanted to focus our time and engineering resources on developing the application and solving related problems. And Torizon helped us to achieve this goal
Adrian Aschwanden,
Features
CPU Name | NXP i.MX 95 |
CPU Type | Up to 6x Arm Cortex-A55 |
Microcontroller | 1x Arm Cortex™-M7 1x Arm Cortex®-M33 |
CPU Clock | 1800MHz (A55) 800MHz (M7) 333MHz (M33) |
RAM | Up to 16GB LPDDR4x (32 Bit) |
Flash | Up to 128GB eMMC |
USB 3.2 | 1x OTG (Gen 1) |
USB 2.0 | 1x Host |
Ethernet | Gigabit with TSN and AVB (+2nd RGMII) |
Wi-Fi | 2.4/5 GHz Dual-band 1x1 Wi-Fi 6 (802.11ax) |
Bluetooth | Bluetooth 5.2 |
PCIe | 1x (x1 Gen3) |
I2C | 7x |
I3C | 1x |
SPI | 6x |
QSPI | 1x |
UART | 8x |
PWM | 21x |
GPIO | 10x + 84x |
Analog Input | 8x |
SDIO/SD/MMC | 2x |
CAN FD | 5x |
JTAG | 1x |
Neural Processing Unit (NPU) | Yes (2 TOPS) |
Integrated ISP | Yes |
Display Controller | Single (Dual Engine) |
2D Acceleration | Yes |
3D Acceleration | Yes |
Video Decoder | Yes (H.264/AVC and H.265/HEVC) |
Video Encoder | Yes (H.264/AVC and H.265/HEVC) |
Display Serial Interface | 1x Quad Lane MIPI DSI (up to 4k) |
LVDS | 1x (up to 1920x1080) |
Digital Audio | 2x I2S |
S/PDIF (RX and TX) | 1x |
PDM Mic Input | 4x |
Camera Serial Interface | 2x Quad Lane MIPI CSI-2 |
Q1 2025 | |
Q1 2025 | |
Q1 2025 | |
Contact Us | |
Coming Soon | |
Contact Us |
Size | 69.6 x 35.0mm |
Power Dissipation | TBD |
Product Availability | 2039+ |
Verdin iMX95 Quad
2GB
A55
A55
A55
A55
M7
M33
3D GPU
NPU
ISP
VPU
2GB RAM
16GB FLASH
0° to 70° C
- Sample Quantity
- 1-99
- Get Updates
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX95 Quad
2GB Wi-Fi / Bluetooth IT
A55
A55
A55
A55
M7
M33
3D GPU
NPU
ISP
VPU
2GB RAM
16GB FLASH
-40°C to +85°C
- Sample Quantity
- 1-99
- Get Updates
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX95 Quad
4GB IT
A55
A55
A55
A55
M7
M33
3D GPU
NPU
ISP
VPU
4GB RAM
32GB FLASH
-40°C to +85°C
- Sample Quantity
- 1-99
- Get Updates
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX95 Quad
4GB Wi-Fi / Bluetooth IT
A55
A55
A55
A55
M7
M33
3D GPU
NPU
ISP
VPU
4GB RAM
32GB FLASH
-40°C to +85°C
- Sample Quantity
- 1-99
- Get Updates
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX95 Hexa
8GB IT
A55
A55
A55
A55
A55
A55
M7
M33
3D GPU
NPU
ISP
VPU
8GB RAM
64GB FLASH
-40°C to +85°C
- Sample Quantity
- 1-99
- Get Updates
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Verdin iMX95 Hexa
8GB Wi-Fi / Bluetooth IT
A55
A55
A55
A55
A55
A55
M7
M33
3D GPU
NPU
ISP
VPU
8GB RAM
64GB FLASH
-40°C to +85°C
- Sample Quantity
- 1-99
- Get Updates
- Volume Quantity
- 100 - 200,000
- Get Volume Quote
Guide MeNeed More Than Just a SoM?
Talk to us about Single Board Computers, Complete Products and Customized Solutions.
Toradex Single Board Computers come with fully integrated software support that allows you to focus on your product. Start developing your software on day one. Long-term Supported Software Stack. Prototype to Volume. Stay Flexible.
Complete Ready-to-use Devices
Complete Solutions offers off-the-shelf, ready-to-use products, including a software stack to speed up your development process and lower time-to-market.
Customized Products
With Custom Product Solutions, you have many different starting points available for your customization. Start with our Complete Devices, Carrier Boards, or even our Systems on Module (SoMs) and tailor it to your exact requirements.
- Customize & Design
- Manufacture
- Manage & Maintain
Carrier Boards
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
