初めてのお客様は、以下の内容をよくお読みください。
注文
検索結果:5製品中1-5
並べ替え
  表示件数
V1.1C
Colibri iMX7 Solo 256MB
ボリューム製品
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $65.80
    $63.20
    $59.25
    $56.60
限定在庫
V1.1A
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $69.00
    $66.25
    $62.10
    $59.35
限定在庫
V1.1A
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $60.70
    $58.25
    $54.65
    $52.20
限定在庫
V1.1A
Colibri iMX6ULL 512MB IT
ボリューム製品
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $55.80
    $53.60
    $50.25
    $48.00
限定在庫
V1.1A
Colibri iMX6ULL 256MB
ボリューム製品
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 528 MHz, 256MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $41.25
    $39.60
    $37.15
    $35.50
限定在庫
Have a Question?
