初めてのお客様は、以下の内容をよくお読みください。
注文
検索結果:12製品中1-12
並べ替え
  表示件数
V1.1B
Colibri iMX6 DualLite 512MB IT
PN: 00171101
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $124.95
    $119.95
    $112.45
    $107.45
Due to limited availability and longer lead times, please consider the Y-Version of the module if you do not need the resistive touch and ADC-functionality of the module. For additional information visit our developer page
V1.1Y
PN: 00171124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $124.95
    $119.95
    $112.45
    $107.45
Y-Version of the module does not have the resistive touch and ADC-functionality, but has higher availability and shorter lead time. For additional information visit our developer page
V1.1B
PN: 00151101
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $104.35
    $100.20
    $93.90
    $89.75
V1.1Y
PN: 00151124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $104.35
    $100.20
    $93.90
    $89.75
V1.1B
Colibri iMX6 Solo 256MB
PN: 00141101
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $87.40
    $83.90
    $78.65
    $75.15
V1.1Y
PN: 00141124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $87.40
    $83.90
    $78.65
    $75.15
V1.1B
Colibri iMX6 Solo 256MB IT
PN: 00161101
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $103.15
    $99.00
    $92.85
    $88.70
V1.1Y
PN: 00161124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $103.15
    $99.00
    $92.85
    $88.70
V1.1B
Colibri iMX7 Dual 1GB
PN: 00391101
Volume Production
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to 85° C Temp. Range, Availability until 2035+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $94.35
    $90.60
    $84.95
    $81.15
V1.1D
Colibri iMX7 Dual 512MB
PN: 00331103
Volume Production
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to 85° C Temp. Range, Availability until 2035+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $87.25
    $83.80
    $78.55
    $75.05
V1.1D
Colibri iMX7 Solo 256MB
PN: 00321103
Volume Production
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 Ethernet, -20° to 85° C Temp. Range, Availability until 2035+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $81.10
    $77.90
    $73.00
    $69.75
V3.2B
Colibri 評価ボード
PN: 01013201
Sample Production
  • 数量
    >0
  • 単価
    $220.00
Have a Question?
