検索ワード
注文
初めてのお客様は、以下の内容をよくお読みください。
検索結果:9製品中1-9
並べ替え   表示件数
Volume Product
数量
単価
1-99100-249250-499500-999>999
$99.70$94.10$91.85$89.60RFQ
low stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
Evaluation Product
数量
単価
>0
$229.00
low stock
Evaluation Product
数量
単価
>0
$199.00
in stock
Product Change Notification
This product is only recommended for Colibri PXA modules
Connectivity: USB 2.0: 2x Host (Full Speed), 1x Device (Full Speed), 10/100 Mbit Ethernet, 1x I2C, 2x SPI, 4x PWM, 4x ADC, up to 20 GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 4-wire Resistive Touch
Physical: 7-24V DC Supply Voltage, 5V 5A, 3.3V 5A On-Board Power Supplies, Size: 160 x 100 mm
数量
単価
1-99
$99.00
in stock
Multimedia: Audio out: 1x (Stereo), 4-wire Resistive Touch
数量
単価
1-99
$99.00
in stock
Volume Product
Connectivity: USB 2.0: 1x Host / 1x OTG, 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
数量
単価
$58.25$52.65$49.30$45.95RFQ
in stock
Volume Product
数量
単価
$23.55$22.40$21.30$20.20$19.05
in stock
Volume Product
数量
単価
$29.15$28.00$26.90$25.80RFQ
in stock
Evaluation Product
Small form-factor with header compatible with Arduino Uno and Raspberry Pi (RPi) maker boards
数量
単価
$58.25$54.90$51.55$48.20RFQ
in stock
