検索ワード
絞り込み検索
注文
初めてのお客様は、以下の内容をよくお読みください。
検索結果:30製品中1-15
並べ替え   表示件数
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC*, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
数量
単価
1-99100-249250-499500-999>999
$166.10$159.45$149.50$142.90RFQ
Limited stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
In Development
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
数量
単価
$142.15$136.45$127.95$122.20RFQ
coming soon
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB LPDDR4 (16 Bit), 4GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
数量
単価
$136.25$130.85$122.65$117.20RFQ
coming soon
Sample Product
数量
単価
$114.05$109.45$102.60$98.10RFQ
Limited stock
Colibri T30 1GB | V1.1F
Volume Product
数量
単価
$161.35$154.90$145.20$138.75RFQ
Limited stock
Volume Product
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$176.70$169.65$159.05$151.95RFQ
Limited stock
Volume Product
数量
単価
$131.60$126.35$118.45$113.20RFQ
in stock
Volume Product
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB SLC NAND, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$166.50$159.85$149.85$143.20RFQ
in stock
Volume Product
数量
単価
$119.75$115.00$107.80$103.00RFQ
Limited stock
Volume Product
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB SLC NAND, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$145.00$139.20$130.50$124.70RFQ
in stock
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR3 (64 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
$90.85$87.20$81.75$78.10RFQ
in stock
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 800 MHz , 512MB DDR3 (64 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$102.10$98.05$91.90$87.85RFQ
Limited stock
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 1.0 GHz, 256MB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
$79.85$76.70$71.90$68.70RFQ
in stock
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 800 MHz , 256MB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$89.50$85.95$80.55$77.00RFQ
Limited stock
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$81.50$78.25$73.35$70.10RFQ
Limited stock
