検索ワード
注文
初めてのお客様は、以下の内容をよくお読みください。
検索結果:15製品中1-15
並べ替え   表示件数
Colibri T30 1GB | V1.1F
Volume Product
数量
単価
1-99100-249250-499500-999>999
$161.35$154.90$145.20$138.75RFQ
low stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
Volume Product
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$176.70$169.65$159.05$151.95RFQ
low stock
Volume Product
数量
単価
$131.60$126.35$118.45$113.20RFQ
in stock
Volume Product
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB SLC NAND, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$166.50$159.85$149.85$143.20RFQ
in stock
Volume Product
数量
単価
$119.75$115.00$107.80$103.00RFQ
low stock
Volume Product
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB SLC NAND, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$145.00$139.20$130.50$124.70RFQ
in stock
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR3 (64 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
$90.85$87.20$81.75$78.10RFQ
in stock
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 800 MHz , 512MB DDR3 (64 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$102.10$98.05$91.90$87.85RFQ
low stock
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 1.0 GHz, 256MB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
$79.85$76.70$71.90$68.70RFQ
in stock
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 800 MHz , 256MB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$89.50$85.95$80.55$77.00RFQ
in stock
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$81.50$78.25$73.35$70.10RFQ
low stock
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$71.60$68.75$64.45$61.60RFQ
in stock
Product Change Notification
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 1x Cortex™-M4, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB NAND (8 Bit), 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$65.80$63.15$59.25$56.60RFQ
low stock
Volume Product
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
low stock
Evaluation Product
数量
単価
>0
$199.00
in stock
