初めてのお客様は、以下の内容をよくお読みください。
注文
検索結果:6製品中1-6
並べ替え
  表示件数
V1.1D
Colibri iMX7 Solo 256MB
PN: 00321103
ボリューム製品
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $81.15
    $77.90
    $73.05
    $69.80
V1.1A
Colibri iMX6ULL 1GB IT
PN: 00621100
サンプル製品
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz, 1GB DDR3L (16 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $68.75
    $66.00
    $61.90
    $59.15
V1.1A
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT
PN: 00401100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $81.15
    $77.90
    $73.05
    $69.80
V1.1A
PN: 00451100
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $70.00
    $67.20
    $63.00
    $60.20
V1.1A
Colibri iMX6ULL 512MB IT
PN: 00441100
ボリューム製品
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $58.70
    $56.40
    $52.85
    $50.50
V1.1A
Colibri iMX6ULL 256MB
PN: 00361100
ボリューム製品
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 528 MHz, 256MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $46.75
    $44.90
    $42.10
    $40.20
Have a Question?
