初めてのお客様は、以下の内容をよくお読みください。
注文
検索結果:8製品中1-8
並べ替え
  表示件数
V1.2B
Colibri T20 512MB
PN: 00211201
製品変更通知
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $167.50
    $160.80
    $150.75
    $144.05
V1.2A
Colibri T20 512MB IT
PN: 00221200
製品変更通知
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB SLC NAND, 10/100 Mbit Ethernet, -40° to 85° C Temp. Range, Availability until 2025
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $199.40
    $191.40
    $179.45
    $171.50
V1.2A
Colibri T20 256MB
PN: 00201200
製品変更通知
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $136.15
    $130.70
    $122.55
    $117.10
V1.2A
Colibri T20 256MB IT
PN: 00241200
製品変更通知
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB SLC NAND, 10/100 Mbit Ethernet, -40° to 85° C Temp. Range, Availability until 2025
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $166.25
    $159.60
    $149.65
    $143.00
V1.2C
PN: 00241202
製品変更通知
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $166.25
    $159.60
    $149.65
    $143.00
V1.2B
Colibri VF61 256MB IT
PN: 00121201
ボリューム製品
NXP® Vybrid™ VF6XX, 1x Arm Cortex™-A5, 500 MHz (A5), 167 MHz (M4), 256MB DDR3 (16 Bit) (or 128MB with ECC), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2028
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $81.15
    $77.90
    $73.05
    $69.80
V1.2B
Colibri VF50 128MB
PN: 00101201
ボリューム製品
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2028
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $54.90
    $52.70
    $49.40
    $47.20
V1.2B
Colibri VF50 128MB IT
PN: 00131201
ボリューム製品
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2028
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $64.35
    $61.80
    $57.95
    $55.35
Have a Question?
