検索ワード
注文
初めてのお客様は、以下の内容をよくお読みください。
検索結果:4製品中1-4
並べ替え   表示件数
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
1-99100-249250-499500-999>999
$81.50$78.25$73.35$70.10RFQ
low stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$71.60$68.75$64.45$61.60RFQ
in stock
Product Change Notification
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 1x Cortex™-M4, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB NAND (8 Bit), 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$65.80$63.15$59.25$56.60RFQ
low stock
Volume Product
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
low stock
