検索ワード
注文
初めてのお客様は、以下の内容をよくお読みください。
検索結果:7製品中1-7
並べ替え   表示件数
Volume Product
数量
単価
1-99100-249250-499500-999>999
$131.60$126.35$118.45$113.20RFQ
in stock
Volume Product
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB SLC NAND, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$166.50$159.85$149.85$143.20RFQ
in stock
Volume Product
数量
単価
$119.75$115.00$107.80$103.00RFQ
low stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
Volume Product
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB SLC NAND, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
$145.00$139.20$130.50$124.70RFQ
in stock
Volume Product
NXP® Vybrid™ VF6XX, 1x Arm Cortex™-A5, 500 MHz (A5), 167 MHz (M4), 256MB DDR3 (16 Bit) (or 128MB with ECC), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$63.60$61.05$57.25$54.70RFQ
low stock
Volume Product
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB NAND (8 Bit), 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
$45.25$43.45$40.70$38.90RFQ
in stock
Volume Product
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB NAND (8 Bit), 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$54.75$52.60$49.30$47.10RFQ
low stock
