検索ワード
絞り込み検索
注文
初めてのお客様は、以下の内容をよくお読みください。
検索結果:7製品中1-7
並べ替え   表示件数
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR3 (64 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
1-99100-249250-499500-999>999
$90.85$87.20$81.75$78.10RFQ
in stock
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 800 MHz , 512MB DDR3 (64 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$102.10$98.05$91.90$87.85RFQ
Limited stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 1.0 GHz, 256MB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
単価
$79.85$76.70$71.90$68.70RFQ
in stock
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 800 MHz , 256MB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$89.50$85.95$80.55$77.00RFQ
Limited stock
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$81.50$78.25$73.35$70.10RFQ
Limited stock
Volume Product
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$71.60$68.75$64.45$61.60RFQ
in stock
Volume Product
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
数量
単価
$65.80$63.15$59.25$56.60RFQ
Limited stock
