検索ワード
見積依頼
検索結果:21製品中1-15
並べ替え   表示件数
Apalis T30 2GB | V1.1A
Product Change Notification
数量
単価
1-99100-249250-499500-999>999
$185.50$178.10$166.95$159.55RFQ
Limited stock
現在在庫僅少です。詳しくは こちら からお尋ねください。
Apalis T30 2GB | V1.1B
Volume Product
数量
単価
Limited stock
Apalis T30 1GB | V1.1A
数量
単価
$167.90$161.15$151.10$144.40RFQ
in stock
Apalis T30 1GB | V1.1B
Volume Product
数量
単価
Limited stock
Volume Product
数量
単価
$188.90$181.35$170.00$162.45RFQ
Limited stock
Volume Product
数量
単価
$153.70$147.55$138.35$132.20RFQ
in stock
Volume Product
数量
単価
$125.65$120.60$113.10$108.05RFQ
in stock
Volume Product
数量
単価
$131.65$126.35$118.50$113.20RFQ
Limited stock
Volume Product
数量
単価
Limited stock
Colibri T30 1GB | V1.1F
Volume Product
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB Flash, 10/100 Mbit Ethernet, 0° to 70° C Temp. Range, Availability until 2025
数量
単価
$164.90$158.30$148.40$141.80RFQ
Limited stock
Volume Product
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB Flash, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
単価
Limited stock
Volume Product
数量
単価
$90.85$87.20$81.75$78.10RFQ
in stock
Volume Product
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 800 MHz , 512MB DDR3 (64 Bit), 4GB Flash, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$102.15$98.05$91.95$87.85RFQ
Limited stock
Volume Product
数量
単価
$79.80$76.60$71.85$68.65RFQ
in stock
Volume Product
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 800 MHz , 256MB DDR3 (32 Bit), 4GB Flash, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
単価
$89.50$85.95$80.55$77.00RFQ
Limited stock
