Order Now
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
Unit Price$65.80$63.20$59.25$56.60
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2032
Unit Price$69.00$66.25$62.10$59.35
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2032
Unit Price$60.70$58.25$54.65$52.20
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2032
Unit Price$55.80$53.60$50.25$48.00
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 528 MHz, 256MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2032
Unit Price$41.25$39.60$37.15$35.50
Limited stock
