You've Selected
Order Now
Results: 1-2 of 2 products.
Sort By   View
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 2x Arm Cortex™-M4F, 1.6GHz (A72) , 1.26GHz (A53) , 266MHz (M4)
640 MHz (DSP), 4GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C(2) Temp. Range, Availability until 2030
(2) The RAM on the first Samples is not IT-grade, but will be changed in the future. Furthermore, the Wi-Fi component on the module is limited to an operating temperature range of -30° to +85°C. As this component is not deemed boot-critical, the Apalis iMX8QM 4GB WB IT is still listed as an Industrial Temperature product.
coming soon
In Development
640 MHz (DSP), 4GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030
coming soon
