You've Selected
Narrow Results
Order Now
Results: 1-11 of 11 products.
Sort By   View
Quantity
Unit Price
1-99100-249250-499500-999>999
Limited stock
In Development
Quantity
Unit Price
coming soon
Quantity
Unit Price
Limited stock
In Development
Quantity
Unit Price
coming soon
coming soon
In Development
coming soon
In Development
coming soon
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC*, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
$166.10$159.45$149.50$142.90RFQ
Limited stock
In Development
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
$142.15$136.45$127.95$122.20RFQ
coming soon
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2GHz (A35), 266MHz (M4), 1GB LPDDR4 (16 Bit), 4GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
$136.25$130.85$122.65$117.20RFQ
coming soon
Sample Product
Quantity
Unit Price
$114.05$109.45$102.60$98.10RFQ
in stock
