Order Now
Unit Price$283.20$271.90$254.90$243.60
Limited stock
Unit Price$263.15$252.65$236.85$226.35
Limited stock
Unit Price$241.05$231.40$216.95$207.30
Limited stock
Unit Price$220.75$211.90$198.65$189.85
Coming soon
Unit Price$249.90$239.90$224.90$214.90
Limited stock
Unit Price$190.80$183.20$171.75$164.10
Coming soon
Unit Price$185.40$177.95$166.85$159.45
Coming soon
Unit Price$130.45$125.25$117.40$112.20
Coming soon
Unit Price$185.50$178.10$166.95$159.55
Limited stock
Limited stock
Unit Price$167.90$161.15$151.10$144.40
In stock
Limited stock
Unit Price$188.90$181.35$170.00$162.45
Limited stock
Limited stock
Limited stock
Limited stock
Limited stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Unit Price$166.10$159.45$149.50$142.85
Limited stock
Unit Price$142.10$136.45$127.90$122.20
Limited stock
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB LPDDR4 (16 Bit), 4GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Unit Price$136.25$130.80$122.60$117.15
Limited stock
