Order Now
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 16GB Flash, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
Unit Price$283.20$271.90$254.90$243.60
Limited stock
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 16GB Flash, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Unit Price$263.15$252.65$236.85$226.35
Limited stock
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 2GB LPDDR4 (64 Bit), 16GB Flash, Gigabit with AVB (+2nd RGMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Unit Price$241.05$231.40$216.95$207.30
Limited stock
Unit Price$220.75$211.90$198.65$189.85
Coming soon
Unit Price$249.90$239.90$224.90$214.90
Limited stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB DDR3L (32 Bit), 16GB Flash, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2035+
Unit Price$190.80$183.20$171.75$164.10
Coming soon
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB DDR3L (32 Bit) with ECC, 16GB Flash, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2035+
Unit Price$185.40$177.95$166.85$159.45
Coming soon
NXP® i.MX 8DualXPlus, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB DDR3L (32 Bit), 8GB Flash, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2035+
Unit Price$130.45$125.25$117.40$112.20
Coming soon
Unit Price$185.50$178.10$166.95$159.55
Limited stock
Limited stock
Unit Price$167.90$161.15$151.10$144.40
In stock
Limited stock
Unit Price$188.90$181.35$170.00$162.45
Limited stock
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 800 MHz, 2GB DDR3 (64 Bit), 4GB Flash, Gigabit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Limited stock
Limited stock
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 800 MHz, 1GB DDR3 (64 Bit), 4GB Flash, Gigabit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Limited stock
Limited stock
Unit Price$111.90$107.40$100.70$96.20
In stock
In stock
Quantity>0
Unit Price$245.00
In stock
