Order Now
Unit Price$190.80$183.20$171.75$164.10
Coming soon
Unit Price$185.40$177.95$166.85$159.45
Coming soon
Unit Price$130.45$125.25$117.40$112.20
Coming soon
Unit Price$185.50$178.10$166.95$159.55
Limited stock
Limited stock
Unit Price$167.90$161.15$151.10$144.40
In stock
Limited stock
Unit Price$188.90$181.35$170.00$162.45
Limited stock
In stock
In stock
Limited stock
Limited stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Unit Price$166.10$159.45$149.50$142.85
Limited stock
Unit Price$142.10$136.45$127.90$122.20
Limited stock
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB LPDDR4 (16 Bit), 4GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Unit Price$136.25$130.80$122.60$117.15
Limited stock
Unit Price$114.00$109.45$102.60$98.05
In stock
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB Flash, 10/100 Mbit Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Unit Price$164.90$158.30$148.40$141.80
Limited stock
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB Flash, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Limited stock
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB Flash, 10/100 Mbit Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Unit Price$137.90$132.35$124.10$118.60
Limited stock
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB Flash, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Unit Price$174.30$167.35$156.90$149.90
Limited stock
