PN: 00461000
coming soon
coming soon
coming soon
coming soon
low stock
low stock
in stock
low stock
low stock
in stock
in stock
low stock
low stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
low stock
coming soon
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2GHz (A35), 266MHz (M4), 1GB LPDDR4 (16 Bit), 4GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
coming soon
