You've Selected
Order Now
Results: 1-15 of 22 products.
Sort By   View
Quantity
Unit Price
1-99100-249250-499500-999>999
Limited stock
In Development
Quantity
Unit Price
coming soon
Quantity
Unit Price
Limited stock
In Development
Quantity
Unit Price
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
Quantity
Unit Price
Limited stock
coming soon
NXP® i.MX 8M Mini Quad, 4x Arm Cortex™-A53
1x Arm Cortex™-M4F, 1.6GHz (A53)
400MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC (8bit), Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
(1)The Wi-Fi component on the module is limited to an operating temperature range of -30° to +85°C. As this component is not deemed boot-critical, the Verdin iMX8M Mini 2GB WB IT is still listed as an Industrial Temperature product.
coming soon
In Development
coming soon
In Development
coming soon
Apalis T30 2GB | V1.1A
Product Change Notification
Quantity
Unit Price
Limited stock
Apalis T30 2GB | V1.1B
Volume Product
Quantity
Unit Price
Limited stock
Apalis T30 1GB | V1.1A
Quantity
Unit Price
in stock
Apalis T30 1GB | V1.1B
Volume Product
Quantity
Unit Price
Limited stock
Volume Product
Quantity
Unit Price
Limited stock
Volume Product
Quantity
Unit Price
in stock
