Order Now
Unit Price$111.90$107.40$100.70$96.20
In stock
In stock
Quantity>0
Unit Price$245.00
In stock
Quantity>0
Unit Price$219.00
In stock
Connectivity: USB 2.0: 1x Host / 1x OTG, 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
Unit Price$54.60$52.45$49.15$46.95
Limited stock
Limited stock
Unit Price$26.60$25.55$23.95$22.90
In stock
Unit Price$32.35$31.05$29.10$27.85
In stock
Quantity>0
Unit Price$61.50
In stock
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB Micro-B (OTG), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 109x GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 1x S/PDIF In / Out.
Physical: 6-27V DC Supply Voltage, Size: 250mm x 200mm
Quantity>0
Unit Price$318.00
Limited stock
Physical: 5-27V DC or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
Quantity>0
Unit Price$148.90
Limited stock
