You've Selected
Order Now
Results: 1-8 of 8 products.
Sort By   View
Product Change Notification
Quantity
Unit Price
1-99100-249250-499500-999>999
$99.70$94.10$91.85$89.60RFQ
low stock
Quantity
Unit Price
>0
$229.00
low stock
Evaluation Product
Quantity
Unit Price
>0
$229.00
low stock
Evaluation Product
Quantity
Unit Price
>0
$199.00
in stock
This product is only recommended for Colibri PXA modules
Connectivity: USB 2.0: 2x Host (Full Speed), 1x Device (Full Speed), 10/100 Mbit Ethernet, 1x I2C, 2x SPI, 4x PWM, 4x ADC, up to 20 GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 4-wire Resistive Touch
Physical: 7-24V DC Supply Voltage, 5V 5A, 3.3V 5A On-Board Power Supplies, Size: 160 x 100 mm
Quantity
Unit Price
1-99
$99.00
in stock
Connectivity: USB 2.0: 1x Host / 1x OTG, 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
Quantity
Unit Price
$58.25$52.65$49.30$45.95RFQ
low stock
Volume Product
Quantity
Unit Price
$29.15$28.00$26.90$25.80RFQ
in stock
Evaluation Product
Small form-factor with header compatible with Arduino Uno and Raspberry Pi (RPi) maker boards
Quantity
Unit Price
$58.25$54.90$51.55$48.20RFQ
in stock
