You've Selected
Order Now
Results: 1-15 of 20 products.
Sort By   View
coming soon
In Development
coming soon
In Development
coming soon
Apalis T30 2GB | V1.1A
Product Change Notification
Quantity
Unit Price
1-99100-249250-499500-999>999
$185.50$178.10$166.95$159.55RFQ
Limited stock
Apalis T30 2GB | V1.1B
Volume Product
Quantity
Unit Price
Limited stock
Apalis T30 1GB | V1.1A
Quantity
Unit Price
$167.90$161.15$151.10$144.40RFQ
in stock
Apalis T30 1GB | V1.1B
Volume Product
Quantity
Unit Price
Limited stock
Volume Product
Quantity
Unit Price
$188.90$181.35$170.00$162.45RFQ
Limited stock
Volume Product
Quantity
Unit Price
$153.70$147.55$138.35$132.20RFQ
in stock
Volume Product
Quantity
Unit Price
$125.65$120.60$113.10$108.05RFQ
in stock
Volume Product
Quantity
Unit Price
$131.65$126.35$118.50$113.20RFQ
Limited stock
Volume Product
Quantity
Unit Price
Limited stock
Evaluation Product
Quantity
Unit Price
>0
$245.00
in stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 2GB LPDDR4 (32 Bit), 8GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
$166.10$159.45$149.50$142.85RFQ
in stock
In Development
Quantity
Unit Price
$142.10$136.45$127.90$122.20RFQ
coming soon
