You've Selected
Order Now
Results: 1-8 of 8 products.
Sort By   View
Volume Product
Quantity
Unit Price
1-99100-249250-499500-999>999
in stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
Limited stock
Volume Product
Quantity
Unit Price
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2028
Quantity
Unit Price
$68.95$66.20$62.10$59.30RFQ
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2028
Quantity
Unit Price
$60.70$58.25$54.60$52.20RFQ
Limited stock
Volume Product
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Quantity
Unit Price
$55.85$53.60$50.25$48.00RFQ
Limited stock
Volume Product
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 528 MHz, 256MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2028
Quantity
Unit Price
$41.25$39.60$37.15$35.50RFQ
Limited stock
