You've Selected
Order Now
Results: 1-10 of 10 products.
Sort By   View
Quantity
Unit Price
1-99100-249250-499500-999>999
$283.20$271.90$254.90$243.60RFQ
Limited stock
In Development
Quantity
Unit Price
coming soon
Quantity
Unit Price
$241.05$231.40$216.95$207.30RFQ
Limited stock
In Development
Quantity
Unit Price
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
Quantity
Unit Price
$249.90$239.90$224.90$214.90RFQ
Limited stock
coming soon
In Development
coming soon
In Development
coming soon
Evaluation Product
Quantity
Unit Price
>0
$245.00
in stock
Verdin Development Board with HDMI Adapter
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB Micro-B (OTG), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 109x GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 1x S/PDIF In / Out.
Physical: 6-27V DC Supply Voltage, Size: 250mm x 200mm
Quantity
Unit Price
>0
$318.00
Limited stock
