You've Selected
Order Now
Results: 1-14 of 14 products.
Sort By   View
Quantity
Unit Price
1-99100-249250-499500-999>999
$283.20$271.90$254.90$243.60RFQ
Limited stock
In Development
Quantity
Unit Price
coming soon
Quantity
Unit Price
$241.05$231.40$216.95$207.30RFQ
Limited stock
In Development
Quantity
Unit Price
coming soon
coming soon
In Development
coming soon
In Development
coming soon
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
Quantity
Unit Price
$131.40$126.15$118.30$113.05RFQ
Limited stock
(1)The Wi-Fi component on the module is limited to an operating temperature range of -30° to +85°C. As this component is not deemed boot-critical, the Verdin iMX8M Mini 2GB WB IT is still listed as an Industrial Temperature product.
In Development
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 8GB Flash, Gigabit with AVB Ethernet, -40°C to 85°C Temp. Range, Availability until 2030+
Quantity
Unit Price
$111.35$106.90$100.20$95.75RFQ
coming soon
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 2GB LPDDR4 (32 Bit), 8GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
$166.10$159.45$149.50$142.85RFQ
in stock
In Development
Quantity
Unit Price
$142.10$136.45$127.90$122.20RFQ
coming soon
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB LPDDR4 (16 Bit), 4GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
$136.25$130.80$122.60$117.15RFQ
coming soon
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz , 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2028
Quantity
Unit Price
$69.00$66.25$62.10$59.35RFQ
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70 °C Temp. Range, Availability until 2028
Quantity
Unit Price
$60.70$58.25$54.65$52.20RFQ
Limited stock
