You've Selected
Narrow Results
Order Now
Results: 1-15 of 34 products.
Sort By   View
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72) , 1.26 GHz (A53) , 266 MHz (M4)
Quantity
Unit Price
1-99100-249250-499500-999>999
Limited stock
In Development
Quantity
Unit Price
coming soon
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72) , 1.26 GHz (A53) , 266 MHz (M4), 2GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
Limited stock
In Development
Quantity
Unit Price
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
Quantity
Unit Price
Limited stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB DDR3L (32 Bit), 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
coming soon
In Development
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB DDR3L (32 Bit) with ECC, 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
coming soon
In Development
NXP® i.MX 8DualXPlus, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB DDR3L (32 Bit), 4GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
coming soon
Apalis T30 2GB | V1.1B
Volume Product
Quantity
Unit Price
Limited stock
Apalis T30 1GB | V1.1A
Product Change Notification
Quantity
Unit Price
in stock
Apalis T30 1GB | V1.1B
Volume Product
Quantity
Unit Price
Limited stock
Volume Product
Quantity
Unit Price
Limited stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
Limited stock
