Order Now
Unit Price$283.20$271.90$254.90$243.60
Limited stock
Unit Price$263.15$252.65$236.85$226.35
Limited stock
Unit Price$241.05$231.40$216.95$207.30
Limited stock
Unit Price$220.75$211.90$198.65$189.85
Coming soon
Unit Price$249.90$239.90$224.90$214.90
Limited stock
Unit Price$190.80$183.20$171.75$164.10
Coming soon
Unit Price$185.40$177.95$166.85$159.45
Coming soon
Unit Price$130.45$125.25$117.40$112.20
Coming soon
Unit Price$185.50$178.10$166.95$159.55
Limited stock
Limited stock
Unit Price$167.90$161.15$151.10$144.40
In stock
Limited stock
Unit Price$188.90$181.35$170.00$162.45
Limited stock
Limited stock
Limited stock
Limited stock
Limited stock
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
Unit Price$131.40$126.15$118.30$113.05
In stock
Unit Price$113.10$108.60$101.80$97.25
Coming soon
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 8GB Flash, Gigabit with AVB Ethernet, -40°C to 85°C Temp. Range, Availability until 2030+
Unit Price$111.35$106.90$100.20$95.75
Coming soon
